What is needed for 2 maps?
Old Nov 19, 2008 | 09:08 AM
fastassfourdoor's Avatar
Im trying to get a 93 octane map and a c16 map on the stock ecu. What all do i need for my tuner to be able to do this?
Old Nov 19, 2008 | 09:11 AM
GTLocke13's Avatar
Go look in the ECUflash forum. I believe some of Tephra's ECU patches allows this.
Old Nov 19, 2008 | 09:13 AM
Import Junky's Avatar
Well you're going to need quite a few things. You'll need to have Ecu controlled boost. This requires a JDM Map Sensor....same as USDM X MAP Sensor. You'll also need a Boost Control Solenoid like the GM 3-PORT. You'll need to Flash your rom with a couple of patches. First the Tephra v5.10 patch. Then you'll have to look up mrfred and check out his threads on ecu controlled boost and jdm map sensor mods.
derekste's Avatar
It involves wiring a switch to your ECU. Look for the AltMap mods in the ECUflash forum.
Old Nov 19, 2008 | 09:15 AM
derekste's Avatar
You do not need a JDM/EvoX MAP or ECU boost control to do map switching....
Old Nov 19, 2008 | 10:11 AM
BigValley's Avatar
If you have a laptop and a tactrix cable, you could carry around both maps and switch em when you need to.
Old Nov 19, 2008 | 11:49 AM
sorry I was thinking on the fly. I'm in the middle of Alt Map switching with my meth kit. sorry to confuse.
Old Nov 21, 2008 | 04:42 AM
uhhh i guess ill just let my tuner handle all this...sounds confusing to me
Old Nov 22, 2008 | 03:34 PM
Jack_of_Trades's Avatar
I offer alt map switching harness' that work with Tephra's v5.10 patch so if you go that route I have what you might need.
babaz7
May 27, 2021 11:35 PM
3011carlos
Jun 9, 2017 07:20 PM
egis
Jan 6, 2016 07:55 PM
dadsgts
Apr 16, 2010 12:19 PM
MR
36
Mar 27, 2010 10:51 PM
