BEC and WGDC Change %
Old Nov 17, 2008 | 03:50 PM
sharkm87's Avatar
bump for help, my wgdc change stays at 0 and -3.087 for boost error correction...
Old Nov 17, 2008 | 04:13 PM
sharkm87's Avatar
request id 8a 0.0241*x-3.087 (boost error)
request id 8b 0.5*x-64 ( wgdc correction)
is this right?
Old Nov 17, 2008 | 07:45 PM
sharkm87's Avatar
i think i found the issue the left side of the BEC and TBEC aren't matched up...i know the tbec is -20 to 20 and the bec is -3 to 3..but thats not what i'm seeing...and i checked the xml and its exactly whats listed so i'm not sure whats being mis calculated.
Old Nov 18, 2008 | 03:15 AM
sharkm87's Avatar
ok so now here is where i am.
i was able to get the left side of BEC and TBEC to show correctly by changing the endian to big on the boosterrorpsi..which i searched and finally found!!...
however, still my evoscan reads -3.081 across the board on my boost error, and my wgdc% stays at 0..
when i get home i will post up my tables so you can see my boost adder is 14.7 and Baseline boost is set at 24.6...now my jdm map is readin around these numbers because i basically been tuning off the wgdc...however I want my error correction to start functioning right.
Old Nov 18, 2008 | 06:05 AM
sharkm87's Avatar
bump, someone has to know the fix to this....ps rom is evo 8 94170008
Old Nov 18, 2008 | 09:31 AM
sharkm87's Avatar
ok i think i may have fixed, but need to test...turns out i had to change the endian to "big"....but it wasn't shown in my room..had to read above to find that one out....but anywho...gonna test in a couple hours to see if this resolves it..hopefully it does.
Old Nov 18, 2008 | 07:22 PM
sharkm87's Avatar
resolved
Old Nov 19, 2008 | 09:10 AM
tnt1106's Avatar
do you get any stutter under light driving when you lift foot off the throttle?
lets say when under 3 psi boost? open or closed loop.
Old Nov 20, 2008 | 09:37 AM
sharkm87's Avatar
yes, i do actually
S15me2
Dec 8, 2016 08:22 PM
okevolutionVIII
Jul 29, 2016 01:13 AM
03Ev0luti0n
Aug 4, 2015 12:32 PM
philr8
Nov 24, 2010 08:38 AM
razorlab
Mar 20, 2008 11:28 AM
