Can the Turboxs Knocklight be hooked to service light flash
Old Dec 6, 2008 | 07:06 PM
  #31
dan l's Avatar
If you have a 1/2 amp quick blow fuse inline you won't hurt the ecu even if you tried. Well maybe if you really tried (like wrapping the fuse with aluminum foil) but realistically you won't.......
Old Dec 6, 2008 | 07:17 PM
  #32
travman's Avatar
Yeah I should have added that to my diagram, def. should have a quick blow fuse installed inline of the 12v signal just for safety.
Old Dec 6, 2008 | 07:25 PM
  #33
black E's Avatar
you mean between the LED and the power source right?
Old Dec 6, 2008 | 07:42 PM
  #34
dan l's Avatar
You always fuse as close to the power source as physically possible. The job of a fuse is to protect the wire so that it doesen't catch on fire. Its an added benefit if it protects the ecu, which a 1/2 amp quick blow will.
Old Dec 7, 2008 | 10:08 AM
  #35
tobz's Avatar
So while my first post seemed sarcastic, that was what I was eluding too. The TXS "knock" light has a good chance of ruining the output on your ecu (if your lucky). An LED works just fine........
No worries brotherman, I just want it right.
Old Dec 9, 2008 | 03:05 PM
  #36
vroomevo's Avatar
awesome...i will get some red led too..
Old Dec 9, 2008 | 03:31 PM
  #37
sikrsix's Avatar
Question. I already have the led for an upgrade like this (RED LED) That 1.8v 20ma led need the 560 ohm resistor or do all leds need the resistor? The leds i have are 12V plug and play. Do i just hook it up minus the resistor and add a 1/2 amp inline fuse? Thanks
Red led will be my "knock light" too. Dumb steering column gauges!
Old Dec 10, 2008 | 08:59 AM
  #38
travman's Avatar
If its a 12v led then you wont need the resistor......the ones I have are 1.8v so the resistor is needed.
Old Dec 10, 2008 | 09:05 AM
  #39
tobz's Avatar
Very Nice Location. I like it alot....
Old Dec 10, 2008 | 01:34 PM
  #40
sikrsix's Avatar
Thanks a lot for the answer and the comment.
cweav
Mar 23, 2016 04:28 PM
JohnEB
Nov 4, 2010 08:01 PM
Rough 01
21
Sep 2, 2010 04:04 PM
Reed44
Sep 18, 2007 05:27 PM
SubiEvolved
Jul 15, 2004 09:34 PM
