HELP: unable to read/write to ECU with ECUFLASH
Old Dec 15, 2008 | 01:09 AM
evolved lancer's Avatar
yup that is the error i am getting.
i tried different cables/laptops, reinstalling and installing software.
i will try the disconnecting and charging the battery longer tomorrow. thanks for the input guys.
Old Dec 15, 2008 | 01:22 AM
evo4mad's Avatar
check continuity between the 12pin reflash plug (officially pin26, but really its pin 5 or last of 3 on the notch side, its the corner pin) and the ecu harness (pin 79) see the XLS doc on my website if you don't know which is pin 79. 3rd pin from the right on the top row.
Old Dec 15, 2008 | 01:23 AM
evo4mad's Avatar
I pull the power during reflash testing everyday, never had my evo7/8 ecus become non flashable yet.
Old Dec 19, 2008 | 05:45 PM
tried charging longer and tried disconnecting the battery but still no luck.
Checked the ecu harness for pin 79 also
On the reflash plug, is there suppose to be a corner pin that sticks out? kind of like a needle in the female plug?
Old Dec 19, 2008 | 06:57 PM
~BoOsTeR~'s Avatar
Originally Posted by evolved lancer
I cannot to read/write to ECU with ECUFLASH.
I was able to flash without any problem until my battery ran out of juice. I recharged it and now everything works fine except that it cannot be flashed.
I read some prior threads about this and so far I've tried:
new battery, checked fuse, unlock tool (even though I know it isn't locked), reinstall and install ECUFlash, different laptop, different cable
Evoscan works fine so I'm guessing it has to do with the smaller white plug, not the OBDII plug.
Any help will be appreciated
Thanks
Try doing what tephra said after the car has been warmed up to full operating temp. I'm guessing the car is cold; my own car is very finicky when it is cold. Blast the heater to warm the ecu and then read and write immediatlely after you kill the engine.
Old Dec 21, 2008 | 02:59 PM
evo4mad's Avatar
yeah really focus on that pin 79 plug (EEPROM reflash voltage line), make sure it has connectivity to that reflash wire on the cable. check with a voltmeter the voltage during reflashing attempts. let me know what it it.
Old Dec 21, 2008 | 03:01 PM
evo4mad's Avatar
if you can, try a friends ecu in place of yours, see if it can be reflashed, will tell you if its the wiring or the ecu itself.
Broke4speed
Aug 6, 2017 07:57 PM
Carvs
Sep 7, 2016 02:21 PM
Wmu240
Dec 18, 2015 10:18 AM
Wmu240
Sep 8, 2015 06:21 PM
