Tons of knock...need some advice
Old Dec 16, 2008 | 02:38 PM
xtturbox's Avatar
thank's ....will do a pressure test tomorrow
Old Dec 20, 2008 | 01:45 AM
xtturbox's Avatar
Pressure test complete....no leaks??!!
Old Dec 20, 2008 | 08:41 AM
Ted B's Avatar
Have you noticed any oil consumption?
Old Dec 20, 2008 | 06:57 PM
cfdfireman1's Avatar
Do a pull from 2500 to 7500 @ 100% TPS and post that.
Old Dec 21, 2008 | 05:18 AM
gsrboi80's Avatar
Am I losing my mind
1. Your 2byte Load isnt right
2. No WOT pull
3. Your fuel map is kind rich and your Ignition Map has very little timing in it
If I were you I would certainly have the car looked over then brought somewhere for a tune or work with one of our E-Flash tuners to get the car making power again
Old Dec 21, 2008 | 10:09 PM
funks's Avatar
Originally Posted by xtturbox
better pics
Use ALT-PRINTSCREEN (keyboard keys) to take an active window snapshot via Windows, then paste it to an Image Program like PAINT.NET (Free) then save it as a JPG.
Old Dec 21, 2008 | 10:20 PM
casper980's Avatar
Raynham Ma, ....I have 2 full hours of logging just broken up...
here are a few more...
This vehicle was purchased with what seems to be a ton of work... not all done correctly but right now I am having problem with knock-timing-fuel
Car has a 20g 9lt with 650cc injectors, 22lbs boost, full exhaust no cat, lc-1 wideband, intercooler upgraded, cams....not sure which ones, block was redone to a stroker motor also with lower compression to run high boost.
you need larger injectors, 880's would probably help
Old Dec 22, 2008 | 02:42 PM
xtturbox's Avatar
Ok will try the 2500 to 7500 in 3rd on Christmas...
funks...thanks for the info on print screen.
Ted... no real oil consumption as of yet, I have only driven about 500(hard) miles this month.
Old Dec 28, 2008 | 09:01 PM
when?
Old Dec 29, 2008 | 10:04 AM
xtturbox's Avatar
when?
I logged on the 25th and yesterday the 28th but haven't had time to look at it or upload it yet....will do tomorrow the 30th
thanks
Old Jan 16, 2009 | 09:51 AM
30th of when?
YaroRS
Nov 7, 2012 10:43 AM
vicbdn
Jul 28, 2008 09:41 PM
erggy
Apr 23, 2007 08:48 AM
SophieSleeps
Feb 21, 2007 10:29 AM
steelcityevo8
AEM EMS
17
Jan 31, 2007 09:22 AM
