Question about EGR Disable
Old Dec 22, 2008 | 01:35 PM
evane's Avatar
Okay, I'm getting a P0401 and i've already edited my ROM for Periphery 2 and changed it to EDDF to disable the EGR....i'm just curious if its alright to have this disabled while the egr valve and everything else is still on the car? i will be ordering a block off plate tonight most likely...
so i'm just curious if its alright to have everything still on the car and have it disabled? before i reflash my ecu
i'm guessing it should be fine because i have my rear o2 sensor disabled and its still on the car
Old Dec 22, 2008 | 01:44 PM
travman's Avatar
Yeah - i have mine disabled and still on the car, I just unhooked the lines from the tb and plugged the ends and capped the tb nipples off.
Old Dec 22, 2008 | 01:49 PM
evane's Avatar
will i have to unplug anything and cap anything? or can i just disable the EGR and later put on the block off plate
Old Dec 22, 2008 | 06:52 PM
evo150's Avatar
i have my egr disabled through the ecu, but everything is still hooked up
Old Dec 22, 2008 | 09:04 PM
Deepnine's Avatar
I had removed everything except the egr solenoid, no problems.
I don't see a problem when you leave everything connected.
Old Dec 23, 2008 | 05:48 AM
MR Turco's Avatar
they way i see it you might actually WANT to keep it all hooked up or remove ALL of the components. I believe the EGR valve works every similar to the BOV so removing the vacuum lines might cause gases to push open the valve during boost the valve is tee'd off the intake manifold pressure.
I can't confirm this but i would remove everything or nothing, personally. By removing the coupler to the TB you should be able to get to the valve on the intake manifold very easily. There are only two bolts and the gasket and block off plate should run you <$10 shipped.
Old Dec 23, 2008 | 06:19 AM
evane's Avatar
yeah i plan on getting a block off plate and just capping off the two nipples that the EGR valve lines go to
Old Dec 23, 2008 | 06:32 AM
C6C6CH3vo's Avatar
Might want to cap every thing, the valve leaks both ways whether solenoid activated or not. Disabled, the hoses will eventually deteriate from being static.
Old Dec 23, 2008 | 05:30 PM
JohnBradley's Avatar
0x0001
Old Dec 23, 2008 | 05:33 PM
evo150's Avatar
sounds good
Old Feb 2, 2009 | 04:56 PM
jjm4life's Avatar
any more info on this? im getting a p0401 code. had my egr replaced once, and if i can just disable it, and leave everything plugged in as it is now, that would be awesome. any downsides to this?
Old Feb 2, 2009 | 05:22 PM
silverstream's Avatar
Sorry for a newbie question: What's the advantage of running w/o EGR ?
Old Feb 2, 2009 | 06:52 PM
McLaren F1 2003's Avatar
subscribed...
Old Feb 2, 2009 | 07:05 PM
Dapper Dan's Avatar
you should block it off, with no vacuum going to it it can just sit there opened.
Old Feb 3, 2009 | 04:46 AM
Kracka's Avatar
Keeps your intake manifold clean since there won't be exhaust gasses running through it and cleans up some of the clutter from the engine bay.
