Omni 4bar map sensor Plug and Play
Wouldn't the 4bar just need different scalings for the boost control tables?
25 psi of boost would be roughly a raw bit count of 214 using the JDM 3bar. So your desired boost table is 25 psi, which is 214 raw.
That same 214 bit count would correspond to ~36 PSI on the 4bar. Thus, the ECU would try to reach the raw bit count of 214, giving you 36 psi instead of 25 PSI that is reflected using the 3 bar scaling.
The ECU just looks at the raw bit count, it has no idea if you have a 3 bar or 4bar. The ECU tables just need to be scaled to reflect the 4bar.
But honestly, I haven't tuned closed loop boost at all (I use a manual controller) so I could be completely wrong.
Any settings reference, or location to look for?
Hey guys. After installing the omni 4 bar, I've noticed a lean spike of over 18.4 (aem wideband) when slightly lifting off the throttle after boosting. Has anyone else experienced this? Any ideas?
D-VO, I am seeing similiar. If I lift I go flat line on my AEM Wideband. Of ourse I am also experiencing stutter, hesitation and misfire when I push the throttle over 25% at about 3k - 5k. I also just installed my 272's at the same time though...
By chance do you have the scalings for ECUFlash and EVO scan on the Omni 4 Bar, I don't hink mine is reading right. My boost guage says higher than Evo Scan does...
Any help on this would be tremendous. Thanks
*Now that I'm looking at this, shouldn't the map scaling table go upto 5 volts and not 3.63? I thought the omni map sensors read from 0 - 5 volts. Could that be whats causing the lean spike? Does anyone else have this problem?
For EVOScan: What I did was copied the "JDMMap" code in the xml to create a second one and named it "Omni 4 bar", then changed the formula to 0.238683*x-(add your atmospheric pressure here), so in case I need to log JDMMap on someone elses car I'll still have the correct formula for the 3 bar.
BTW: I've noticed this stuttering issue coming up again in recent posts. Didn't this have something to do with the P0300 code or blown head gasket or something. I used to have this problem too, but my memory is a bit spotty on the answer.
96940011:
<table name="MAP Scaling" category="MAPSensor" address="57d2" type="2D" level="1" scaling="uint8">
<table name="MAP Output" address="6ed4" type="Y Axis" elements="9" scaling="Volts16"/>
</table>
<table name="MAP Fault Trig: Mid VE Max #1" category="MAPSensor" address="28b4" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Fault Trig: Mid VE Min #1" category="MAPSensor" address="2894" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Fault Trig High VE #1" category="MAPSensor" address="289a" type="1D" level="1" scaling="Volts16"/>
<table name="MAP vs MAF Baro" category="MAPSensor" address="2802" type="1D" level="1" scaling="uint16"/>
<table name="EGR MAP offset #1" category="MAPSensor" address="44fa" type="2D" level="1" scaling="uint8">
<table name="RPM" address="623c" type="Y Axis" elements="9" scaling="RPM"/>
</table>
<table name="EGR MAP offset #2" category="MAPSensor" address="450a" type="2D" level="1" scaling="uint8">
</table>
<table name="EGR Pressure Diff" category="MAPSensor" address="1b68" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Comparison" category="MAPSensor" address="27fe" type="1D" level="1" scaling="Volts16"/>
The rest are here: https://www.evolutionm.net/forums/ec...tructions.html
</table>
</table>
</table>
Omni Power 4 & 7 Bar MAP Sensors ($100 shipped): http://www.stikiller.com/product.php...age=1&featured
