need Evo 9 owner to test rear O2 *heater* sim patch
Old Feb 18, 2009 | 11:27 AM
  #91
mrfred's Avatar
Originally Posted by acamus
I am speaking of sub_32946 in 88590015
Code:
ROM:00032956                 mov     r5, r2          ; r5' -> r2
ROM:00032958                 mov     r4, r1          ; r4' -> r1
ROM:0003295A                 mov     #0, r0
ROM:0003295C                 mov.w   r0, @(8,r14)
ROM:0003295E                 mov     #0, r9
ROM:00032960                 mov.w   r0, @(h'C,r14)
ROM:00032962                 extu.w  r2, r2
ROM:00032964                 extu.w  r2, r10
ROM:00032966                 tst     r10, r10
ROM:00032968                 bt      loc_32980
ROM:0003296A                 mov     r2, r0
ROM:0003296C                 cmp/eq  #1, r0
ROM:0003296E                 bt      loc_32980
ROM:00032970                 mov     r2, r0
ROM:00032972                 cmp/eq  #h'C, r0
ROM:00032974                 bt      loc_32980
ROM:00032976                 mov     r2, r0
ROM:00032978                 cmp/eq  #h'D, r0
ROM:0003297A                 bt      loc_32980
Keep looking further down in that sub. There are tests for other values e.g. 0x200, 0x400, etc for r4. r5 runs as high as 0xD or something like that. Its been a few weeks since I reviewed the range of values. Take a look at the OBD-II code table for the 88590015 ROM. That will show the range of values and how they correspond to OBD-II codes.
Old Feb 18, 2009 | 11:59 AM
  #92
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
I have been looking down the routine and even further
unk_FFFF61BE at the end of this routine is the completion status of non-continuous OBD checks,
this one is used in sub_3A834(one could call it PROCESS_OBD_MODE_1_REQUEST), PID 1 is then handled at
loc_3A8E6 and when you follow it at loc_3A928 is the copy to serial buffer D part of OBD request.
Now non-continuous OBD checks are handled within sub_32946 and unk_FFFF61BE is set here (one could call it SET_NON_CONTINUOUS_MONITOR_COMPLETION_STATUS).
unk_FFFF6180 bit coded DTC for lookup in OBD table is set in sub_3289C (one could call it SET_DTC_AND_NON_CONTINUOUS_MONITOR_COMPLETION_STAT US).
Maybe now we will understand each other
Old Feb 18, 2009 | 12:35 PM
  #93
mrfred's Avatar
I don't have my PC handy with IDA, but I remember now that r5 ranges from 0 to F, and 0,1 and C,D are special values that correspond to bank 1 and bank 2 values. So if the car is a V6, I think 0 and C correspond to bank 1 codes and 1 and D correspond to bank 2 codes. That's why those values handled differently than the other r5 values.
There is a separate subroutine that is called when an OBD-II test does not pass. I forget the address, but maybe its one that you mention. I'll try to look this evening at the subroutines that you listed. I think you're getting pretty far ahead of me now in this area. I think that your work in OBD subroutine disassembly is paying off. :-)
Old Feb 19, 2009 | 12:30 AM
  #94
acamus's Avatar
Thumbs up
Yes, you are correct these values 0,1,C,D are something else.
EDIT: Please use Post #117 instead
But now I think we can change
Code:
00032D1C                 extu.w  r0, r10
to
00032D1C                 mov  h'FF, r10  (mov     #-1, r10)
so speaking hex 6A0D to EAFF and all non-continuous monitors checks should pass.
Anyone with this ROM and capable OBD device to try this out?
Code:
<table name="OBD non-continuous monitor passed" address="32d1c" type="1D" level="1" scaling="Hex16"/>
Attached Thumbnails need Evo 9 owner to test rear O2 *heater* sim patch-passed.jpg
Old Feb 19, 2009 | 05:54 AM
  #95
travman's Avatar
This is awesome.....I have been hoping for something like this for a long time.
I can test it out asap because my front O2 would not complete and also I have egr disabled in the periphery so it would never complete either....
So I will check to see if the do in fact complete with this change.
Thanks
Old Feb 19, 2009 | 06:16 AM
  #96
acamus's Avatar
I forgot to mention, but this should help only with non-continuous tests as stated below
Catalyst monitoring
Heated catalyst monitoring
Evaporative system monitoring
Secondary air system monitoring
A/C system refrigerant monitoring
Oxygen sensor monitoring
Oxygen heater sensor monitoring
EGR system monitoring
Old Feb 19, 2009 | 06:47 AM
  #97
travman's Avatar
Catalyst monitoring
And those are the ones that cause the most grief at inspection with all the rom mods and things we can disable in the periphery tables.
Old Feb 19, 2009 | 06:54 AM
  #98
acamus's Avatar
I am mentioning that because there are also continuous monitoring checks available e.g. O2 sensor threshold tests as seen in ScanTech under Mode 5 Tab.
Old Feb 19, 2009 | 08:00 AM
  #99
mrfred's Avatar
Code:
ROM:00032D1C                 extu.w  r0, r10
to
ROM:00032D1C                 mov  h'FF, r10  (mov     #-1, r10)
Code:
Can you write this definition in blobbit format (like periphery bits) and associate each non-continuous test with its own bit? Then it would be possible to disable individual OBD-II tests with periphery bits and set monitor to pass with your blobbit definition for those disabled OBD-II tests.
Old Feb 19, 2009 | 09:34 AM
  #100
travman's Avatar
Ok went out and tested this with scantech monitors
Catalyst monitoring - Complete
Heated catalyst monitoring - N/A
Evaporative system monitoring - Complete
Secondary air system monitoring - N/A
A/C system refrigerant monitoring - N/A
Oxygen sensor monitoring - Complete
Oxygen heater sensor monitoring - Complete
EGR system monitoring - N/A
For some reason EGR is showing not supported now? but it is def. required for an OBD-II test on the evo. I believe the other N/A's are not supported from my memory (but could be wrong).....
So I would say it partially works at this moment.
Old Feb 19, 2009 | 10:31 AM
  #101
acamus's Avatar
Great, thank you for testing, it works as expected.
The first part is easy. There are actually two parts of this,
one says what checks are available, and the second if they are passed.
The second we have already
I will try to find simple solution for the first part.
mrfred, ok will do
Old Feb 20, 2009 | 01:58 AM
  #102
acamus's Avatar
EDIT: see post #117
Old Feb 20, 2009 | 05:06 AM
  #103
travman's Avatar
First apply the patches:
Code:
	<table name="Non-Continuous Monitor Availability Patch Part 1" category="OBD Inspection" address="3a90c" type="1D" level="1" scaling="Hex16"/>
	<table name="Non-Continuous Monitor Availability Patch Part 2" category="OBD Inspection" address="3a926" type="1D" level="1" scaling="Hex16"/>
	<table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="32d1c" type="1D" level="1" scaling="Hex16"/>
from 6A0D to EAFF
from 4019 to E020
from 2BA1 to EBFF
Once done one can use definitions for monitoring availability/completion
Code:
	<table name="Monitor Available(1)/Not Available(0)" category="OBD Inspection" address="3a927" type="2D" level="2" scaling="blobbits">
		<table name="Non-Continuous Monitor Availability Bits" type="Static Y Axis" flipy="true" elements="8">
			<data>EGR system</data>
			<data>Oxygen heater sensor</data>
			<data>Oxygen sensor</data>
			<data>A/C system refrigerant</data>
			<data>Secondary air system</data>
			<data>Evaporative system</data>
			<data>Heated catalyst</data>
			<data>Catalyst</data>
		</table>
	</table>
	<table name="Monitor Passed(1)/Failed(0)" category="OBD Inspection" address="32d1d" type="2D" level="2" scaling="blobbits">
		<table name="Non-Continuous Monitor Completion Bits" type="Static Y Axis" flipy="true" elements="8">
		</table>
	</table>
travman can you retest extended patch? You already have Non-Continuous Monitor Completion Patch.
Will do....probably wont get to it till early evening (gotta go on a road trip for work today) - will post my findings.
Thanks!
Old Feb 20, 2009 | 07:12 AM
  #104
mrfred's Avatar
Sorry to keep asking for more detail, but:
P0401 code only? <data>EGR system</data>
Front or rear or both? (P0032, P0032 = front heater; P0037, P0038 = rear heater <data>Oxygen heater sensor</data>
Front or rear or both? Which tests? <data>Oxygen sensor</data>
For USDM, only P1530 is A/C related. Maybe this is for non-USDM cars? <data>A/C system refrigerant</data>
Is this the SAS anti-lag for JDM?<data>Secondary air system</data>
Which codes?<data>Evaporative system</data>
P0420? <data>Heated catalyst</data>
What code could this be? <data>Catalyst</data>
Old Feb 20, 2009 | 07:16 AM
  #105
acamus's Avatar
mrfred, I have not gone into deep details of this, It does not remove the CEL, it just fools the inspection equipment to be able to pass your emission inspection, but one can track it backwards to DTC. Those routines are full-time man-month disassembly effort, which I do not see as necessary. As you remember I have been hunting for heater check for half a year
This patch allows you to "pass" inspection even if you have CEL. I mean together with unplugging the light, not to look suspicious in front of the inspector .
The names are as stated in ISO standard.
