need Evo 9 owner to test rear O2 *heater* sim patch
Old Mar 7, 2009 | 05:49 PM
  #151
travman's Avatar
Acumus,
Finally tested the latest update you sent me and it works like a charm - very exciting stuff here, so glad to never have to worry about inspection again.
Thanks a ton for getting this setup
Old Mar 8, 2009 | 07:14 AM
  #152
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Im glad it worked , actually same instructions as I have send you are described in post #117
Old Mar 9, 2009 | 04:59 AM
  #153
acamus's Avatar
Originally Posted by magyar86
I was wondering if you could make a inspection patch for rom 96940011 (05 evo).
Here come inspection bits for 96940011 '05 EVO8 USDM,
First apply the patches:
Code:
	<table name="Non-Continuous Monitor Availability Patch Part 1" category="OBD Inspection" address="39E24" type="1D" level="1" scaling="Hex16"/>
	<table name="Non-Continuous Monitor Availability Patch Part 2" category="OBD Inspection" address="39E4E" type="1D" level="1" scaling="Hex16"/>
	<table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="39E54" type="2D" level="1" scaling="Hex16">
		<table type="Static Y Axis" elements="2">
			<data>39E54</data>
			<data>39E56</data>
		</table>
	</table>
@39E54 DA66 -> EAFF
@39E56 6AA1 -> 6AA7
@39E24 4019 -> E000
@39E4E 6AA1 -> EAFF
Once done one can use following definition:
Code:
	<table name="Monitor Available(1)/Not Available(0)" category="OBD Inspection" address="39E4F" type="2D" level="2" scaling="blobbits">
		<table name="Non-Continuous Monitor Availability Bits" type="Static Y Axis" flipy="true" elements="8">
			<data>EGR system</data>
			<data>Oxygen heater sensor</data>
			<data>Oxygen sensor</data>
			<data>A/C system refrigerant</data>
			<data>Secondary air system</data>
			<data>Evaporative system</data>
			<data>Heated catalyst</data>
			<data>Catalyst</data>
		</table>
	</table>
	<table name="Monitor Passed(1)/Failed(0)" category="OBD Inspection" address="39E55" type="2D" level="2" scaling="blobbits">
		<table name="Non-Continuous Monitor Completion Bits" type="Static Y Axis" flipy="true" elements="8">
		</table>
	</table>
If anyone is willing to donate money for inspection bits patch please donate to tephra!
Old Mar 10, 2009 | 11:36 PM
  #154
fireroasted's Avatar
Just wanted to see if there was anything new on this. I have 88590015 and still throwing the P0031 CEL. I have applied MrFred's rear 02 heater sim
https://www.evolutionm.net/forums/6691277-post59.html
but the code keeps coming back. I have quadruple checked my settings of the tables and the values.
Does anyone have any ideas? Are others trying this mod and having no issues?
catless, rear 02 IN the car.
THX
M
P.S. Are the front and rear 02 interchangeable (cable length permitting)? As was considering a swap just to give me a troubleshooting angle to work on.
Old Mar 11, 2009 | 03:05 AM
  #155
krazykorean84's Avatar
I looked up the DTC code P0031 on Alldatadiy.com and its shows P0031 being "heated oxygen sensor heater control circuit low, sensor 1 (front)" so this indicates that your problem is not with the rear O2 sensor but that the problem is the front O2 sensor. Sorry about getting your hopes up with Mr. Fred's rear O2 heater sim.
I'm not sure if there is a sim for the front O2 but its sounds like your front O2 sensor is going bad or maybe there is some sort of problem with the connection or cable. Just my .02 cents. Good luck.
Old Mar 11, 2009 | 03:59 AM
  #156
amui07's Avatar
Does the 94170015 rom fix for all the readiness codes work the same as the 94170014 rom? If so, i'll just copy those changes.
Old Mar 11, 2009 | 05:53 AM
  #157
acamus's Avatar
Yes, the locations and values for inspection bits are the same for both 94170014 and 94170015.
Old Mar 11, 2009 | 07:27 AM
  #158
amui07's Avatar
Great thanks to Acamus for his work on obdII inspection bits. Works like a charm.
Old Mar 11, 2009 | 12:37 PM
  #159
fjo_newport's Avatar
Why can't I edit the tables after I do this mod on ROMID 96940011?
The table looks like this:
Old Mar 11, 2009 | 12:46 PM
  #160
travman's Avatar
what version of ecuflash?
Old Mar 11, 2009 | 12:48 PM
  #161
krazykorean, thanks. (I will check continuity of the front 02 sensor and report back). Any all ideas help. I checked on this forum and others all responded that the 0031 is rear, but...
Can anyone or several confirm if the 0031 code is expressly front or rear 02 heater circuit?
That would help my process a lot. Also, knowing that I could switch them (front and rear) temporarily would help me troubleshoot by process of elimination.
Old Mar 11, 2009 | 01:07 PM
  #162
both 1.40.2178 and the newest (1.41).
Thanks
Old Mar 11, 2009 | 01:18 PM
  #163
l2r99gst's Avatar
You need the blobbits scaling.
Old Mar 11, 2009 | 02:33 PM
  #164
I just copied the XML from post 153, it looks like it has the blobbits scaling. On another computer I tried using 1.41, still the same results?
Old Mar 11, 2009 | 05:10 PM
  #165
The front and rear have different connectors on them. So I would need to cut them just for this test, which didn't seem like a good idea. The front 02 also passed a continuity test easily, so all wires right up to the sensor have connectivity without issue.
M
