need Evo 9 owner to test rear O2 *heater* sim patch
Old Feb 4, 2009 | 11:32 PM
  #46
GotWheelHop's Avatar
Originally Posted by justboosted02
will this pass emissions?
That is the whole point of this patch. It is going to simulate the rear o2 heater signal, therefore the ECU will think that there is still a sensor attached. You will have to run an o2 simulator, like the one found in the v5.10 Tephra roms, or Mrfred's separate o2 sim.
Old Feb 4, 2009 | 11:34 PM
  #47
We ready to test 94170015 yet?
BTW, I may be headed up your way for work soon mrfred. We need to have a if I do.
Old Feb 5, 2009 | 05:27 AM
  #48
MR Turco's Avatar
Originally Posted by tephra
ouch!
don't take it personally, he is just lazy!
Old Feb 5, 2009 | 07:15 AM
  #49
mrfred's Avatar
I've been pretty busy at work, so no patch yet at all. Hoping later this week I can get started.
Beer sounds good. :-) Just give me a call or PM when you are headed this way.
Old Feb 12, 2009 | 10:06 PM
  #50
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Talking
mrfred, I know you have been busy with SD, but any updates on this?
Old Feb 12, 2009 | 10:24 PM
  #51
mrfred's Avatar
Yes, dexmix has been testing it. Its working properly. :-) I just need to spend a bit of time preparing a patched ROM and the tables. I'll probably post it up tomorrow evening.
Old Feb 12, 2009 | 10:49 PM
  #52
acamus's Avatar
Maybe you can PM/post code sequences to see what you have changed?
Old Feb 12, 2009 | 10:53 PM
  #53
mrfred's Avatar
Yep. I'll do that. The quick summary is that I wrote a new subroutine that simply calls the OBD-II reset routine when engine speed is less than 2000 rpm, and that's it. Doing it this way saves some ECU cycles for other things. :-)
Old Feb 13, 2009 | 08:09 AM
  #54
fostytou's Avatar
EvoM Community Team
I'm guessing this would present a "not ready" status to emissions testing equipment then?
...Does it wind up resetting any other status or is the call specific to that code? I'm guessing the ECU doesn't call the check when above 2k?
Old Feb 13, 2009 | 10:14 AM
  #55
mrfred's Avatar
It shows "complete" in OBD-II diagnostics. :-) My subroutine replaces only the rear O2 heater OBD-II code. This technique of calling the OBD-II reset routine can be used for any OBD-II test though, so for any OBD-II test that cannot be fully disabled using a periphery bit, this is the simplest solution to obtain a "complete" readiness status.
Correct, it doesn't call it above 2k rpm. No point in wasting ECU cycles on something like OBD-II diagnostics when going WOT.
Old Feb 13, 2009 | 10:29 AM
  #56
fostytou's Avatar
EvoM Community Team
Wooohooo! Awesome!
Old Feb 13, 2009 | 05:45 PM
  #57
Kracka's Avatar
Just let me know when you want it tested
Old Feb 13, 2009 | 06:10 PM
  #58
tephra's Avatar
mrfred what the address of the rear02 heater check routine?
Old Feb 13, 2009 | 08:06 PM
  #59
mrfred's Avatar
Sorry for taking so long to get this posted. A *stock* patched 88590015 ROM and the accompanying xml definitions are in the link below. Add the definitions to your ECUFlash 88590015 definition file, open your current ROM, and then copy the table values from the stock patched ROM to your current ROM. Flash to your ECU and no more rear O2 heater CEL.
tephra, do you want me to email you a copy of the source code?
http://se30.dyndns.org:8080/EVO/8859...CEL_fix_v1.zip
Old Feb 14, 2009 | 06:27 AM
  #60
Kracka's Avatar
Thanks! I will try this today.
