quick sanity check
Old Feb 1, 2009 | 03:48 PM
tephra's Avatar
quick sanity check
Hi Guys,
ok I had a TB Seal leak, my AFR's were about 11.3.
Since fixed the leak (havn't double checked it thou) and now my AFR's are 10.8
This is all 20+psi...
I *would* have thought the leak would have caused air to escape, and now that I have fixed it would be pushing more air into the engine - thus leaning out the mix???
i dont get??!?
Old Feb 1, 2009 | 03:51 PM
GST Motorsports's Avatar
Have you compared your logged load before/after?
Now that the motor is seeing more pressure you are probably running higher load and going into higher load/richer fuel cels.
Old Feb 1, 2009 | 03:53 PM
tephra's Avatar
I would have thought the load would have dropped of as well, more PSI in IM means turbo has to work LESS to maintain target PSI... meaning less air sucked in intake...
Old Feb 1, 2009 | 03:55 PM
Check your logs.
Old Feb 1, 2009 | 04:04 PM
tephra's Avatar
ok my bad. I just checked a pre-seal-fix and the AFR's + load is about the same...
hrmm maybe my brain is going crazy
6500rpm/24psi/270load/10.8 - bot the same... Let me excel both of these..
Old Feb 1, 2009 | 04:38 PM
MR Turco's Avatar
I fixed a substantial boost leak from my LICP as well as adding the perrin intake and the car was leaned out a lot. TB seals were also changed out but i am not sure the stock ones were leaking.
Old Feb 1, 2009 | 04:57 PM
tephra's Avatar
mmm, I guess I should really redo the boost-leak-test...
Just to verify its all ok...
papabeardoe
Jun 12, 2016 03:27 PM
Cbr1000love
Apr 5, 2016 01:37 PM
EVO8STI
Oct 1, 2010 11:15 AM
storm_trooper
19
Jul 14, 2010 10:23 AM
speifer
Apr 28, 2010 11:30 AM
