SCC aka Spark Control Computer(HWID) at F8A - discussion
Old Feb 11, 2009 | 06:28 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
I guess this question goes to those that have replaced the ROMs in their ECUs.
Did anyone changed ROM that had different HW-ID assuming ROM size is the same?
My goal here is to gain some insight on what ROM-ID can be flashed to what HW-ID.
Maybe one can get cheaper ECU from low-end models and use it with EVO.
Maybe collection of experimental data will show up some patterns.
Old Feb 11, 2009 | 05:08 PM
Deepnine's Avatar
Whats Hardware ID? The label on the board?
Old Feb 11, 2009 | 05:31 PM
Deepnine's Avatar
I should read the title of the topic AND understand it!!!!! :-) :-)
EDIT:
I flashed:
90550001 (HWID:E4B5) on 9339000 (HWID:E4B6)
It works, i can't see any problems.
Old Feb 14, 2009 | 05:20 AM
benpgreen's Avatar
I dont know the HWID but I use the evo rom on an 01 eclipse ecu. I'm pretty sure any 01-05 eclipse ecu will work with the evo 8 rom.
Old Feb 14, 2009 | 05:40 PM
Deepnine's Avatar
wahts the orginal rom id from you eclipse ecu, and whats the evo rom id you are using?
Old Feb 15, 2009 | 04:17 PM
benpgreen's Avatar
I found out I actually had a 2003 ecu the original id was 98950009. I have used 94170008 and 94170015, the only OBD codes I got were for the fuel pump relay and wastegate soleniod which were easily corrected via ecu perephery.
DepoRacing
10
Oct 29, 2010 07:54 AM
EvoPower81
Oct 6, 2010 09:03 AM
nj1266
Oct 19, 2008 01:44 AM
fid
Jul 13, 2008 11:39 AM
