Rom Id Problem--HELP
Old Oct 18, 2008 | 12:30 PM
nj1266's Avatar
Hi Guys,
I am trying to read the rom on a 2006 Evo 9. The car was flashed before. Once I download the rom and look in the Rom Internal Id I see "read_evo9." I have never come across this before.
When I DL the rom I get the "unkown rom image" pop-up window. I then select the "copied from definition below" radio button and select the "2006 Mitsubishi USDM Lancer Evo (88590015)." Then I press next. I get another pop-up window "Rom Identifier." It has two slots:
Address (in hex): f52
Length (in bytes): 4
Below these two slots there is an Identifier box with a new number given for the new rom definition.
The next window is the Rom info window whcih lists the Evo model details and the new xml ID.
After that I can read the rom.
My question is the immobilizer code in the rom accurate? Is the new xml id reading what it is supposed to be reading?
I am concerned about taking the immobilizer code from this badly tuned rom and coping it into one of my base rom and then flashing the car and having it NOT start.
Please help out.
Old Oct 18, 2008 | 07:30 PM
tephra's Avatar
what was the ROMID when you entered 0xf52?
Old Oct 18, 2008 | 09:21 PM
nj1266's Avatar
ECuflash assigned an id number 96940011. I have no idea why or what Evo model/year that rom belongs to. I do not think it belongs to a USDM Evo 9.
Old Oct 18, 2008 | 10:33 PM
MR Turco's Avatar
have you tried loading the normal evo 9 rom? Can you just start fresh?
Old Oct 18, 2008 | 11:01 PM
logic's Avatar
96940011 is the 2005 USDM ROM ID. My guess is that this is the typical change-the-ROM-ID "copy protection" that some tuners think is a good idea. Basically, they've edited the four bytes at 0xf52, and replaced them with something completely wrong.
I suspect if you were to change those four bytes to 0x88590015, you'd be in business.
This is the same thing that happened with my own car; when I bought it the car originally and pulled the image, it was clearly an aftermarket tune, and the ROM ID had been changed to a bogus value (some 2004 ROM ID), but the rest of the ROM was still a perfectly normal 96940011 image. There were also a lot of 8s in the high-octane timing map.
Old Oct 18, 2008 | 11:26 PM
nj1266's Avatar
You are right and it is by the same 8888 dude.
Now, how do I go about changing the four bytes? What should I enter in the Address slot and the Length slot?
Was the immobilizer code the same before and after you fixed the rom? I really do not care about fixing the rom. I just want to be sure that the immobilizer code is accurate. I would hate to flash the car with the immobilizer code that I DLed from the copy protected rom and have the car not start.
Old Oct 18, 2008 | 11:32 PM
TTP Engineering's Avatar
You need a hex editor.
Old Oct 19, 2008 | 12:41 AM
merlin.oz's Avatar
I was trying to find a link to VXI32, and found this one.
Should be ok and free.
http://www.softcircuits.com/cygnus/fe/
Old Oct 19, 2008 | 01:03 AM
EFIxMR's Avatar
or you can add an xml def for the rom id
Old Oct 19, 2008 | 01:11 AM
PeteyTurbo's Avatar
wow thats weird..I think the program I use is called xvi32..https://www.evolutionm.net/forums/sh...itor+scrambled
Old Oct 19, 2008 | 01:44 AM
tephra's Avatar
I just use Ultraedit - its not free, but 28 days free...
nandoliver
Jun 3, 2025 04:11 AM
20psiMR
Feb 25, 2018 08:03 PM
skiestorm
May 13, 2017 06:37 AM
fp-green-95tsi
Oct 25, 2011 03:20 PM
RngrYogi
Jul 9, 2011 07:12 AM
