Is the jdm map sensor required ?
Old Feb 20, 2009 | 09:37 AM
antilag_200's Avatar
ok I downloaded ecuflash 1.41 and everything works correctly. I can change the values for FAA AND FCA.
Do I need to change the values in the tables below also, or am I fine
EGR MAP check 1
EGR MAP check 2
EGR Pressure Diff
and
ECU periphery2
thank you again and if you are ever in the michigan LANSING area, I NEED TO buy you a beer for your help
Old Feb 20, 2009 | 09:47 AM
Appauldd's Avatar
Really I am just glad I could help out.
The Periphery 2 you have realy isn't needed any more. That was an earlier discovery before the full bit listing.
As for the other EGR tables, I don't believe they matter if you disable the EGR using the Bits. Those EGR tables are for the JDM MAP sensor patch you have. I wouldn't mess with them.
Tell you what, you finding me a great deal on a JDM MAP sensor would surely help me out.
Paul
Old Feb 20, 2009 | 10:31 AM
Sounds like a plan, I have a few friends who are at dealerships in michigan, I can see if they have the hook up on the JDM map sensor.
I will keep you posted and once again, I sincerely appreciate all the help you have given me
warren
Old Feb 21, 2009 | 11:30 AM
Paul
sorry to bring this back up , but I loaded the new values that I changed in the FCA AND FAA boxes and all my codes went away, however after about 15 minutes the CEL came on with a p0138 code, I believe this is the rear O2 sensor,
I looked in the attached file to disable the p0138 code, but I did not find it. is there another way to disable it ?
thanks again
maplemaf
Sep 13, 2014 07:39 AM
Toekneee!
Aug 13, 2014 04:03 PM
ninekrevs
Mar 8, 2011 04:27 PM
STIKILLA1084
Aug 10, 2008 08:22 AM
Rich EVO MR SE
Nov 5, 2007 02:35 PM
