ECUFlash rear o2 disabled
Old Feb 21, 2009 | 08:34 AM
amui07's Avatar
I currently have the mod that ignores my rear o2 sensor. Because I have to pass MA inspection, I need to re-enable it since I put in the antifouler. I have a tactrix cable and my tune was on opensource. Does anyone know how to simply remove the rear o2 disable?
Old Feb 22, 2009 | 06:27 AM
recompile's Avatar
At least on EvoIX, you will need to find ECUPeriphery0 (FAA) and set it to 0x5D6A.
If you're stuck, in EcuFlash, go into Options and set User Level to Developer. Find out what ROM version you are by looking at ROM Info > Internal ID. Post that on here, someone should be able to help.
Old Feb 22, 2009 | 04:40 PM
tephra's Avatar
you have an evo8, so I am guessing 94170008..
if you are still running the rear02 but just have the disable mod done you can simply upgrade to my tephramod 941700015 ROM.
that will allow you to pass SMOG or whatever its called...
_RMC_
Apr 11, 2014 12:33 PM
Big Bald
Oct 16, 2013 07:21 PM
deeman101
Mar 3, 2013 01:16 PM
jdmsego
Feb 5, 2010 09:42 AM
evane
Apr 2, 2009 10:14 AM
