TephraMOD V6 - testing!
Old Jul 1, 2009 | 05:55 PM
  #1066
phenem's Avatar
Originally Posted by tephra
ok hows the feedback on V6T7? any problems?
any weirdness?
mrfred has asked me todo a 88590015 - so I want to finalise the code base
Everything is working great for me!
No issues so far...
Old Jul 1, 2009 | 06:17 PM
  #1067
nonschlont's Avatar
Originally Posted by phenem
Adding that to the end of the evo7base.xml is a work around. What you really need is to upgrade to at least 1.41 or the latest version of ECUFlash. If you are not on the latest version that XML will not be there, hence why it can't find it. You renaming it was a temporary fix but I don't know what kind of other issues (maybe like you are having now) that it will present in the future. Upgrade to the latest version, copy in the provided XML and you should be good.
I am not knocking you are trying to be mean, but honestly this is testing and for people that really know their way around the ROM / XML enviornment. Based on your questions and some of the answers you are giving I can tell you really don't know your way around this type of testing. I would be very careful if I were you playing with other cars, other than your own. Honestly these types of questions are geared more towards when the final release is out. If you are still having trouble I would say to wait until the final release is out. Also I created a thread on modding a ROM / XML a long time ago, have you read through that? It explains a lot with screenshots and everything.
Link: https://www.evolutionm.net/forums/ec...ts-others.html
I can appreciate your comment, and understand where your coming from! I have not had much experience w/ other roms, but I have completely modded my own .xml and am comfortable pathing roms from scratch. This is a lil different, than just taking some1 elses "tephra"mod .xmls, and hope they work. The only thing was, I was un-aware that I needed to have the latest version of ecuflash for things to work! Now knowing this, I will upgrade when things have been finalized for the public. I was not gonna patch his rom w/ this, just gonna let him know that the finalized version will be out soon... And I also am just trying to catch up on info I skipped along the way.
Old Jul 1, 2009 | 07:00 PM
  #1068
logic's Avatar
I'll tell you in a day or two.
Old Jul 1, 2009 | 07:13 PM
  #1069
laramie_05MR's Avatar
No issues so far either
Old Jul 2, 2009 | 12:09 AM
  #1070
Asmodeus6's Avatar
I am not set up to take full advantage of all the options available on this new round, but as for the normal driving part of it. No problems. NLTS works, launch maps work, and continue to work, cel/knock works in both stages.
I'll mess with more when my GM BCS comes in. So far so good.
Old Jul 2, 2009 | 12:20 AM
  #1071
tephra's Avatar
I need someone (pref dan l) to test out boost cut on lean-AFR
make sure the timer is working
Old Jul 2, 2009 | 05:01 AM
  #1072
phenem's Avatar
Why? He doesn't know what he is doing....
I just confirmed last night the switch over via TPS or AutoICS works and valet is disabled...as well as AutoICS and valet mode work.
Old Jul 2, 2009 | 08:17 AM
  #1073
evo8dad's Avatar
Anyone getting PO1400 with 96530706? Just curious as I keep getting it on a previous 94170015 car that I converted.
Old Jul 2, 2009 | 08:27 AM
  #1074
l2r99gst's Avatar
Do you have the rear o2 sim active? If not, activate it.
Old Jul 2, 2009 | 09:45 AM
  #1075
evo8dad's Avatar
Yeah I do have that active but, why is that related?? PO1400 is for the MDP sensor?? I've since killed it through peripheries though.
Old Jul 2, 2009 | 09:56 AM
  #1076
l2r99gst's Avatar
p01400? I thought P0140. I didn't think P01400 was a valid code.
If that's an MDP code, then you need to disable EGR from the periphery.
Old Jul 2, 2009 | 10:13 AM
  #1077
RyuEvoIX's Avatar
Do you need a tester for 88590015?
Old Jul 3, 2009 | 09:47 AM
  #1078
logic's Avatar
So far so good on v7t6; I've actually had an opportunity to properly test ADC0F (back on 93 octane for a couple of tanks, trying to get my E10 tune a little closer to where it should be), and switching appears to work as expected; I can also definitely confirm that it wasn't working on v7t5, even though I thought I'd tested that.
I'll try and give the rest of it a workout over the weekend.
Old Jul 3, 2009 | 09:53 AM
  #1079
inco9nito99's Avatar
...patiently waiting for 88590015.
Old Jul 3, 2009 | 10:49 AM
  #1080
recompile's Avatar
Ready to test 88590715. Love you Tephra :-)
