2005 Evo MR WTF is wrong with it???
Old Feb 28, 2009 | 01:25 PM
jslater2306's Avatar
ok well ive purchased a 2005 evo mr, 60k, nice looking car anyways. After logging the car on evo scan on a friends computer, the car was knocking real bad, so i paid buschur to re-tune the car without meth, the car made nice power still had slight knock but buschur was thinking it was due to the crap gas i put in on the turn pike and the fact my plugs and wires were old, so i put new plugs and wires in and it ran incredible, that was at night. The next morning after touching and changing nothing i took my gf to class and the car was breaking up horribly at higher rpms? so me and a friend looked into the car again, tried everything we could still no fix, then swapped out coils packs from his evo to mine, took it for a rip, and it pulled clean consistent runs. So i bought a set of coilpacks off of steelcityevo, put them in turned tho boost down 2psi, and the car ripped ran great no problems, for last night and all day today, but it wouldnt handle 27psi which is what it was tuned at, so after swapping back coil packs, trying another new set of spark plugs, the car pulled a clean run, then a ****ty run, then clean then ****ty, theres no consistency on it, but i noticed at half throttle in higher rpms the blow off valve was going on a ****load(possible that its just touchy) , so we swapped out tials with my friends, do a rip pulls a clean 3rd gear pull, turn around do another and it breaks up, im at a complete and total ****ing loss as what to do with this car, or what it could be if anyone has any idea what could be going wrong, one thing i might be on to, is the car doesnt run ****ty consistently, everytime i log me and my 2 freinds are in the car, now we jokingly said maybe its the weight , but in reality it could possibly be the load on the engine, i think the load cells on my ecu are all ****ed up and need to be worked out thats the issue, but does anyone know what they should be or how i know what to make them? im new to tuning but the car has a tune from buschur on it now just doesnt run consistent, any help is appreciated pleaseeee
Old Feb 28, 2009 | 01:28 PM
Oh the car is a 2005 evo mr, 3065 turbo, tial 44mm wastegate, tial 50mm bov, injen intercooler piping, slightly bigger fmic, act 2600, smc meth injection(turned off) hks 264-280 cams, buschur springs and retainers, 3 inch invidia exhaust
Old Feb 28, 2009 | 01:34 PM
dustin03's Avatar
sounds like maybe the plugs have the wrong gap......
Old Feb 28, 2009 | 01:51 PM
Ph3n1x's Avatar
+1^ Or the gap has changed.
Old Feb 28, 2009 | 02:00 PM
plugs are all gapped to .024 which is where buschur told me to gap them, wires and coil packs are brand new, and the plugs are still in good shape not fouled or anything
97talon420a's Avatar
did that used 2 diff set of plugs and gaped them to .024 gap
Old Feb 28, 2009 | 02:10 PM
smokedmustang's Avatar
Which spring are you running in BOV? Call Mellontunning, and let them look your maps over while on the throttle. That Maybe spark blow-out? UNPLUG/disconnect meth box, not just turn it off. just my 2c
Old Feb 28, 2009 | 02:12 PM
its not the meth we have not had it turn on. and we also tried a different bov
Old Feb 28, 2009 | 02:19 PM
its not the meth , the fuse is pulled on it
Old Feb 28, 2009 | 02:21 PM
dustin03's Avatar
What kind of plugs are you using? It really sounds like ignition problems.
Old Feb 28, 2009 | 02:47 PM
plugs are br7es and br8es
Old Feb 28, 2009 | 02:50 PM
1320 Engineering's Avatar
check the gap and make sure theyre the right plugs...
a shop sold my friend plugs for an rsx and terrible things happened lol
Old Feb 28, 2009 | 03:34 PM
we check the gap twice on to different sets of plugs
Old Feb 28, 2009 | 03:37 PM
Close the gap on the plugs more. Are the threads on your coilpacks on the valve cover stripped? If it's blow-out, this will fix that. is 27psi of boost too much for that turbo? ie: Out of it's effective range, or "Sweet Spot" ??
Old Feb 28, 2009 | 04:57 PM
Toxin's Avatar
If everything that pops in your head fails, you can always take it back to buschur and see what he'll make of it. I'm pretty sure they've seen worse
