Map Color Question
Old Mar 12, 2009 | 05:20 PM
XK120's Avatar
Question Map Color Question
After a long hiatus due to school, I'm just starting to get into ECUFlash again. Yesterday I upgraded and tried opening my current ROM. First thing I noticed was that all of the colors were different. I tried just changing the colormap but that didn't fix the problem. Seems like it's an issue of scale as the change in shade isn't all that discernable between higher/lower values. I've done some searching and I know it seems like my issue is stemming from the number range in the gradient. My question is how do I change that. Is it something that I edit in the XML file? I'm sure it's something simple but I can't seem to find it.
Thanks
Old Mar 13, 2009 | 12:49 AM
merlin.oz's Avatar
Open EcuFlash
File
Options
Default color map
Make your selection...
Old Mar 13, 2009 | 08:06 AM
fostytou's Avatar
EvoM Community Team
If one of the color maps doesn't fit, you can change the min/max values for each defined table. The min/max values don't specify input; rather they change the range for the color gradient.
Old Oct 24, 2009 | 08:56 PM
SyZyGy1394's Avatar
And where might you look to go about this?
Old Oct 25, 2009 | 12:25 AM
Appauldd's Avatar
Open the timing map
Click edit
Click edit map definition
Click the Scalings button on the timing section
find timing
select it
Click edit
You will see the max and min values for display.
Change min to -61
Change max to 61
Click ok
Exit out of EcuFlash and restart it
You will see the colors have changed.
For the fuel table colors
Change scaling AFR
min 8
max 20
Old Oct 25, 2009 | 09:29 AM
SyZyGy1394's Avatar
Originally Posted by Appauldd
Open the timing map
Click edit
find timing
select it
Click edit
Change min to -61
Change max to 61
Click ok
Change scaling AFR
min 8
max 20
Thanks bro!
Old Oct 25, 2009 | 09:32 AM
Evo_Jay's Avatar
Open the timing map
Click edit
find timing
select it
Click edit
Change min to -61
Change max to 61
Click ok
Change scaling AFR
min 8
max 20
+1
Someone at ECUflash should take care of that for the next version.
Old Oct 25, 2009 | 12:07 PM
raasfaas's Avatar
Quick question, anyone know what's the name of this color scheme or how to get it in the later version of ecuflash (1.35 or newer)
This is the default color scheme that 1.29a uses and I can't find it anywhere in the newer ecuflash's. I tried adjusting the min/max like Appauldd suggested but no luck.
It's not a big deal, I just like that color scheme.
Old Oct 25, 2009 | 01:00 PM
nonschlont's Avatar
+1
it looks much better w/ the scaling like this...
Old Oct 25, 2009 | 04:04 PM
Appauldd's Avatar
My suggestion was for the Rainbow color map.
Old Oct 25, 2009 | 05:42 PM
Evo_Jay's Avatar
I dont know what color scheme that is, but I dont think that is the default color scheme for ECUflash 1.29a. Least when I had 1.29 installed that wasnt the default color scheme. AFAIK the default color is/always has been the rainbow scheme.
Old Oct 25, 2009 | 08:06 PM
fostytou's Avatar
EvoM Community Team
You can copy the file for that color scheme from your old install to the new one and switch via the standard options.
Old Oct 25, 2009 | 08:10 PM
Evo_Jay's Avatar
Still they should fix it on the next release of ECUflash. It only happens on a couple ROMs, mainly 96940011 and 96530006.
Old Oct 25, 2009 | 10:31 PM
raasfaas's Avatar
You could be right, I don't even remember what it was...
Thanks fostytou, I'll try that and see if it works out.
xMCxMRx
12
Feb 24, 2017 03:51 AM
W0LF
Sep 15, 2016 08:58 PM
SmurfZilla
Jul 10, 2012 09:23 PM
wazzelby
May 22, 2012 09:31 AM
dsevo
14
Jun 9, 2010 11:52 PM
