Evo Live Map videos on YouTube
Old Mar 20, 2009 | 05:31 AM
  #31
adamweldonjohns's Avatar
that's nifty!
Last edited by adamweldonjohns; Mar 20, 2009 at 05:32 AM. Reason: I spent 30K on a college education and can't spell
Old Mar 20, 2009 | 05:55 AM
  #32
jcsbanks's Avatar
Originally Posted by MR Turco
I would be willing to pay for a polished final version guarantying that some proceeds go to JB of course.
Not saying i wouldn't pay for the current version but if this was optimized there is definitely a market for it.
Try testing the present one first
Old Mar 20, 2009 | 06:32 AM
  #33
MR Turco's Avatar
haha yup tonight! base map is already setup and the Live Map already has the tables setup for my load scaling.
Old Mar 20, 2009 | 06:37 AM
  #34
jcsbanks's Avatar
If you change the load scaling in the ECU, you have to also change it in the PC app to make the ignition map tracing correct. You can savetoxml on the ignition screen, then it will remember your changes next time you load the app.
Old Mar 20, 2009 | 06:48 AM
  #35
wreckleford's Avatar
Just finished coding 96260009, need to add SD to that too. Then I want to do 90550001 and then work out the minimum set of US Evo 8s to do, I think there are two of them?
Waiting patiently for 90550001 to test.
Old Mar 20, 2009 | 06:56 AM
  #36
Chabada15's Avatar
96940011...itll never happen, JCSBanks your genius regardless
Old Mar 20, 2009 | 06:58 AM
  #37
MR Turco's Avatar
yup that is what i meant. I should have said the Live ECU Program.
Old Mar 20, 2009 | 07:02 AM
  #38
vmrevo9's Avatar
Veteran: Air Force
wow JC this is awesome. i plan on making a carputer to take place of my radio and gauges. the goals is to be able to log anytime and modify my map anytime and with this it's going to make it possible! just i have to find a way to log without having the 3 flashing ACD lights all the time lol
Old Mar 20, 2009 | 11:25 AM
  #39
kaymin's Avatar
why do you have the three flashing acd lights?
Old Mar 20, 2009 | 12:09 PM
  #40
fostytou's Avatar
EvoM Community Team
Likely he is talking about the flashing while using the evoscan cable....
FYI vmrevo, the tactrix cable doesn't cause the flashing.
Old Mar 20, 2009 | 01:26 PM
  #41
vmrevo9's Avatar
Veteran: Air Force
yeap thats the cable i'm talking about. i thought i had the tactrix cable but i ordered mine when i ordered evoscan. i might have to look into the tactrix cable for when i do this mod!
thanks fostytou
Old Mar 20, 2009 | 01:43 PM
  #42
kaymin's Avatar
oh, I'd never heard of that happening. I've only used tactrix cables.
Old Mar 20, 2009 | 05:09 PM
  #43
MR Turco's Avatar
After some confusion i did get this to work on the USDM 9
https://www.evolutionm.net/forums/6835842-post22.html
Old Mar 21, 2009 | 12:58 PM
  #44
jcsbanks's Avatar
Bit more work on it as attached - SD VE live mapping.
These tables all have 16 bit values, working on the car.
The RPM VE axis is in ROM, but the MAP VE axis is in RAM. Both the table contents are in RAM.
Old Mar 21, 2009 | 01:19 PM
  #45
MR Turco's Avatar
John, is the alt injector latencies table in RAM, if so could that be added? Wonderful work.
