glitch with 2-byte airflow logging in Logworks
Old Apr 1, 2009 | 04:24 PM
shadow1's Avatar
I can log 2-byte airflow and load perfectly. However, I had to configure the protocol definition for 2-byte airflow in a strange way to make it work. Here are my definitions:
<datachannel id="#00" name="loadmsb" selected="1" units="load" min="0" max="255" expr="x" type="0"/>
<datachannel id="#01" name="loadlsb" selected="1" units="load" min="0" max="255" expr="x" type="0"/>
<datachannel id="#04" name="airflowmsb" selected="0" units="hz" min="0" max="3000" expr="x" type="0"/>
<datachannel id="#05" name="airflowlsb" selected="0" units="hz" min="0" max="3000" expr="x" type="0"/>
I would expect the "max" 2-byte airflow value to be 255 just like with load. If I use 255 as a max, I get weird airflow numbers when I run my Logworks calculation. Even though the bit data never exceeds 255, if I set the max to 3000, then the 2-byte airflow data log and calculation work perfectly. Anyone else notice this?
Old Apr 1, 2009 | 04:31 PM
fostytou's Avatar
EvoM Community Team
the max for any 1 byte value is 255. The max for any 2 byte value is much higher. 255 units would not be able to cover the full range of 2 byte airflow anyway without being evaluated.
See here for more info: https://www.evolutionm.net/forums/6863231-post2.html
Old Apr 2, 2009 | 07:32 AM
C6C6CH3vo's Avatar
No matter what I used in the lsb/msb lines, the 2bite product was twice as sloppy as the rest of the MUT logs in LW. Ended up logging hz another way directly as weel as IDC/IPW
Old Apr 3, 2009 | 04:38 PM
shadow1's Avatar
May I ask how did you end up logging airflow?
Old Apr 3, 2009 | 04:59 PM
tephra's Avatar
the only problem with 2byte is the low/high mismatch that occurs sometimes...
Old Apr 3, 2009 | 05:15 PM
shadow1's Avatar
Care to elaborate?
Old Apr 3, 2009 | 05:21 PM
tephra's Avatar
like when you see a spike upto like 400 load or drop down to 30..
ie when the high byte is transitioning from 0 to 1 and the low byte is transitioning from ~255 to ~0...
Old Apr 3, 2009 | 05:32 PM
shadow1's Avatar
Seems like no one else has noticed this glitch with Logworks.
mplspilot
Dec 5, 2016 03:29 PM
tephra
Jul 25, 2016 02:21 PM
mrfred
Dec 7, 2015 01:49 PM
roni4g63
Nov 14, 2015 11:45 AM
burgers22
Nov 5, 2013 10:13 PM
