MAF Hz formular correction
Old May 29, 2011 | 04:41 AM
burgers22's Avatar
I have been rescaling my MAF and noticed the MAF Hz formula didn't correctly convert from display back to ROM, Not sure if this has been changed in later xmls, but here it is for your interest.
<scaling name="MAFHz" units="Hz" toexpr="6.29*x/64" frexpr="x*64/6.29" format="%.0f" min="0" max="5000" inc="1" storagetype="int16" endian="big"/>
Old May 29, 2011 | 10:57 AM
Dynotech Tuning's Avatar
<scaling name="MAFHz" units="Hz" toexpr="6.29*x/64" frexpr="64/(6.29*x)" format="%.0f" min="0" max="5000" inc="1" storagetype="int16" endian="big"/>
Hmm, nice catch. I will have to see what my current scaling values are now.
-Jamie
(jack_of_trades)
Old May 29, 2011 | 11:48 AM
burgers22's Avatar
It will read the same, but my previous xmls didn't write back correctly. The above fixes that.
Old Feb 19, 2012 | 02:25 PM
Just for preservation sake, I will add the correction here. The formula you posted was the original WRONG one, not the revised one. Here is the corrected one:
-Jamie
Old Feb 21, 2012 | 12:52 PM
burgers22's Avatar
So it was Jamie, sorry about that. First post corrected with corrected formula,
Old Oct 29, 2013 | 04:04 PM
domyz's Avatar
This should be corrected in tephra defs. From what I know, at least 9417 SD 2.0 has the wrong formula.
without the right forumula , it's impossible to edit MAF compensation Y axis (MAFHZ)
Old Oct 31, 2013 | 12:28 AM
merlin.oz's Avatar
Actually the correct eval is x*64/6.25
6.29 will give 1610Hz, but it should be 1600Hz, so 6.25.
A minor detail but if you want to be accurate....
Old Nov 1, 2013 | 08:23 PM
CDrinkH2O's Avatar
What effect will this have on MAF Compensation if I re-flash my existing tune after changing the scaling to the correct definition?
Old Nov 3, 2013 | 12:07 AM
merlin.oz's Avatar
nil effect, it is just to present the data accurately.
Old Nov 5, 2013 | 10:13 PM
CDrinkH2O's Avatar
Cheers Merlin. I was thinking it might impact Maf Comp because the Hertz values I adjusted Comp at changed once I corrected the scaling. Thanks for correcting my misunderstanding.
mrb00st
E85 / Ethanol
189
Oct 11, 2024 04:59 PM
l2r99gst
Aug 28, 2011 03:39 AM
JohnBradley
Dec 9, 2007 07:55 AM
cpoevo
May 3, 2007 08:22 AM
Iamkar33m
21
Jul 29, 2004 06:38 PM
