Misfire or Load Limiter?
Old Apr 14, 2009 | 03:58 PM
Ted B's Avatar
Haven't driven the car awhile until just lately. When I stepped on it, I get heavy misfire when the turbo gets into boost.
Checking the logs, I see a steady 2-byte load of 159.375 at 100% TPS and never more or less. AFR is fine and knock count is zero.
Ordinarily I'd look at the plugs first, but that unwavering 159.375 looks suspiciously like a load limiter of some type as opposed to misfire. Now, I've been tweaking things like ISC steps and such, but I haven't touched the limits. I've rechecked everything, and it all looks square - all limits with disabling values. Reflashing with slightly earlier programs had no effect. I checked for boost leaks not long ago, but I'll redo it.
So, is it the plugs, massive boost leak, or is there a ghost in the machine (ECU)? Hedge your bets.
Old Apr 14, 2009 | 04:01 PM
l2r99gst's Avatar
That is the limit for 1-byte load. Are you sure you are logging 2-byte load correctly?
Old Apr 14, 2009 | 04:06 PM
Ted B's Avatar
Ooops, that's actually "ECU Load". Somehow, 1-byte and 2-byte were inadvertently disabled in EVOScan. (sigh)
Old Apr 15, 2009 | 06:11 AM
SLO-EVO's Avatar
we all make mistakes... did you get it fixed???
Old Apr 15, 2009 | 07:02 AM
tephra's Avatar
im going with plugs
although your AFR would show lean if you are getting misfire...
Old Apr 15, 2009 | 08:33 AM
Ted B's Avatar
Checked for pressure leaks - none except for my already leaky TB.
Changed plugs.
We'll see what happens!
Old Apr 15, 2009 | 09:48 AM
SLO-EVO's Avatar
good luck ted!!!
Old Apr 15, 2009 | 10:54 AM
Ted B's Avatar
Hmm. . . Everything looks good in the log, but MAF Hz will not go above 1593 no matter what. Could be a problem with the MAF.
Old Apr 15, 2009 | 10:59 AM
l2r99gst's Avatar
Looks like the limit for 1-byte airflow.
Old Apr 15, 2009 | 11:12 AM
Ted B's Avatar
Are you suggesting a glitch in the program? I've tried several known good ones, all with the same result. This problem just seemed to pop up out of nowhere. I can't imagine what would have triggered it.
Old Apr 15, 2009 | 11:39 AM
l2r99gst's Avatar
I'm suggesting that you are only logging 1-byte airflow, like the issue with your load log originally.
The limit for 1-byte airflow is somewhere around 1600Hz. If you want to log above that, then you need to log 2-byte airflow. In order to do that, you need the correct addresses for your ROM setup in the MUT requests that you are logging with EvoScan (or whatever logging tool your are using).
I believe EvoScan is setup to look at 2 particular MUT requests for 2-byte airflow (I forgot if it's 2+3 or 4+5), but you need to ensure that the correct variables are in your MUT table if you want to log 2-byte airflow.
Old Apr 15, 2009 | 11:49 AM
Ted B's Avatar
I don't think so, because I've seen over 3000 Hz logging MAF Hz from those same settings, and I've made no changes. Strange isn't it?
santan98
Aug 27, 2014 08:18 PM
Arkitek
18
Jun 27, 2010 06:53 AM
ryant25bb
Lancer Aftermarket Forced Induction Tech
21
Jul 19, 2009 09:51 AM
Creamo3
Feb 3, 2009 01:12 PM
linuxbatm
Dec 24, 2008 04:41 PM
