MIVEC with cams/stroker/large frame turbo
Old May 8, 2009 | 06:40 AM
jcsbanks's Avatar
Not sure on the cam spec yet, but I wondered if anyone had experience or ideas of tuning MIVEC on a 2.2 stroker with Cosworth heads and a GT42? I've tuned big power stuff before but never with VVT.
Factors to consider:
Exhaust manifold pressure
Cam overlap
Octane
Airflow
Engine speed
I could of course set a flat MIVEC profile and test acceleration or power across the range, then draw the best MIVEC plot.
It may be a case where less MIVEC advance gives more torque, and also where less taper is indicated.
Any hints/experience/discussion/theory would be interesting...
Old May 8, 2009 | 07:49 AM
Mr. Evo IX's Avatar
I would add EGT to factors to consider. I would think you'd want more advance at higher rpms.
Here's an informative article if you havent already seen it. It's actually a article about cam gears but since Mivec is an on the fly adjustable intake cam gear...
http://www.team-integra.net/forum/di...g+Common+Topic
Old May 8, 2009 | 08:25 AM
jcsbanks's Avatar
Nice article, thanks.
I suppose we really need to add the effect of the turbo to that though. If we have exhaust manifold pressure greater than inlet manifold pressure if we are pushing the turbo hard for peak power then during valve overlap we'll have flow reversion, so retarding inlet cam timing would be helpful. We might have to do this more on wild cams with a lot of overlap, and less when running a large turbo that keeps the exhaust manifold pressure more sensible. I suppose I'm looking for real world experience on GT35R upwards on how the MIVEC maps have ended up compared to the stock turbo.
Old May 8, 2009 | 11:51 AM
JohnBradley's Avatar
I ran into this last night as I was tuning the basemap on my 3586. The S2 map that I had posted in the MIVEC map was what I had been using with the scaling pretty generic.
Old May 8, 2009 | 12:23 PM
EE's Avatar
EE
If i'm not mistaken 9sec9 had an hta3586 and FP5R cams on his evo 9. It's a 2.0L though, but i'm sure he can be of great help if you shoot him a pm.
Good Luck
Old May 8, 2009 | 12:32 PM
Mr. Evo IX's Avatar
Aaron, do you mean that you were running into significant turbo back pressure or vice versa?
Old May 8, 2009 | 12:36 PM
jcsbanks's Avatar
Aaron, I don't understand also.
Old May 8, 2009 | 02:15 PM
Mr. Evo IX's Avatar
From looking at his Mivec map posted and the dyno plot I think he's saying less advance = more torque although he's not fully retarding the cam at higher rpms. I'd still like to get some clarification.
dudical26
Feb 12, 2013 08:26 AM
YaroRS
Nov 7, 2012 10:43 AM
hackish
15
Oct 2, 2009 08:01 AM
booster9
40
Mar 18, 2009 02:32 PM
madfast
Lancer Engine Tech
15
Jun 25, 2007 07:24 PM
