switch to 88590015
switch to 88590015
Can you please someone help me in order to make all the proper steps in order to switch from my 88840017 to 88590015?
I want to try this swap and I need more infos about the process.
Except periphery immobilizer code what setup needs to me made in order to menage to swap EDM GSR rom to MR?
Thanks
Thanks
Daniel, I was able to start my car, idle and cruise with the standard 88570008 (in case i wanted to switch to jcs's SD rom), all i had to do was disable the immo through periphery, and put the proper injector scalings for my rc1000's.
my stock rom was 88840017, so yeah, it should work for you.
I will try that mate and I will see if it will work.
Except immobilizer code did U disable something else?
My mods are close to 360 uk version but I don`t know what version to try since 360 runs ecutek remap.
What did U try?How was the logging results?
Thanks
daniel, i just disabled immo through periphery and the car started. logged afr and timing for cruise and idle, everything seemed fine. didn't try wot though.
if you change to this rom, make sure to check your afrs, as the car will want to be a bit leaner. injector scaling is set to 542 instead of 513 like our current rom.
