4th gear log to sink your teeth into
Old May 20, 2009 | 04:35 AM
recompile's Avatar
Stock block IX, FP Green, FP 4R. Stock BCS with #65 pill, Forge WGA
93oct V-Power & VP M1 Meth. 1050cc FIC (flow test @ 1100cc) + 500cc 1.0mm Meth Jet
Airflow in Lbs/min is measured (not estimated) using mrfred's airflow rate calc patch. Data corroborated with injector calculations here (injector size includes adjustment for 500cc of meth): http://rallyevo.com:8080/injectors.p...=12&max_idc=50
I estimate 430-440whp. Heading to the track tonight for trap speeds hopefully 122+mph.
Old May 20, 2009 | 05:06 AM
MR Turco's Avatar
you should think about getting a GM BCS, it would help with that taper.
Old May 20, 2009 | 05:17 AM
recompile's Avatar
Yea, I'm sure it will. How much more than 48 lb/min are people able to get out of the Green? I'd also consider a bigger turbo if I wasn't concerned about the stock bottom end.
MR Turco's Avatar
Originally Posted by recompile
Yea, I'm sure it will. How much more than 48 lb/min are people able to get out of the Green? I'd consider a bigger turbo if I wasn't concerned about the stock bottom end.
i am pretty sure you are outside the turbo efficiency already so probably not much more.
Old May 20, 2009 | 11:18 AM
Lazyfong's Avatar
Sorry, but how did you make these nice looks graphs?
Old May 20, 2009 | 11:22 AM
recompile's Avatar
Excel 2007
Old May 20, 2009 | 11:26 AM
MR Turco's Avatar
do you monitor EGTs at all?
Old May 20, 2009 | 11:27 AM
recompile's Avatar
No EGTs unfortunately. I would have logged AFR on this pull but my LC-1 sucks and doesn't always work. AFRs should be in the 12.5 - 12.0 range but I can't say for sure what they were here.
Old May 20, 2009 | 11:28 AM
MR Turco's Avatar
I would be a little nervous of your EGTs with they way you have the car tuned.
Old May 20, 2009 | 11:35 AM
Nurburgring's Avatar
Too much boost?
Timing seems pretty aggresive, that should hold EGT´s within reasonable limits if A/F´s are correct.
Old May 20, 2009 | 11:36 AM
recompile's Avatar
It would definitely be good to know. I've been tuning in this way on this setup (minus the cams) for about a year now. I just replaced my plugs a couple weeks ago, and they looked very good... light browning and no deposits or deformation.
I definitely wouldn't run it this aggressive at any track other than the drag strip.
MR Turco's Avatar
Originally Posted by Nurburgring
Too much boost?
I dunno, it would just be soemthing to see at that aggressive of a tune. mid 12's plus that boost (on a turbo that may not be efficient at it) could equate to high EGTs.
Old May 20, 2009 | 11:37 AM
MR Turco's Avatar
That is why i wouldn't be incredibly worried. Should be fine for drag. Good luck at the track!
Old May 20, 2009 | 01:29 PM
GST Motorsports's Avatar
He already has the forge, and holding 25.5 psi at 7400 on a FPgreen looks to be pretty good to me.
Old May 20, 2009 | 01:32 PM
nonschlont's Avatar
looks like a stong car! GL @ the track!
