Evo X Logging
Old Dec 24, 2009 | 12:52 AM
  #871
tephra's Avatar
For tuning - see Matt Lowth, he uses RE Customs dyno on tuesday/thursday nights
For work I would talk to TMR (Team Mitsubishi Ralliart)
Old Jan 1, 2010 | 11:37 AM
  #872
eTiLiKo's Avatar
Question : When Mode23 is enabled (0x05 -> 0x23 etc.) is it possible to do NON mode23 log (select ecu : EVO X) ?
Old Jan 1, 2010 | 05:34 PM
  #873
tephra's Avatar
yes
Old Jan 3, 2010 | 07:59 AM
  #874
boostin20's Avatar
I had mode 23 stop working with evoscan 2.7beta5 the other day. All the values don't change when I hit start logger with ecu "mode23 usa evo x" selected.I uninstalled/reinstalled, and it's doing the same thing. The tactrix cable and connector are working fine because when I switch to ecu "evo x" (non-mode 23) it logs fine, with values switching regularly; also ecuflash works. My other thread got ignored, so can mfred, tephra, or evo4mad help out? Below is a screen shot of what the values are stuck at every time I hit log with ecu "mode23usaevox" selected. Note, those values always read those same numbers when I hit start.
Old Jan 3, 2010 | 01:18 PM
  #875
SiC's Avatar
SiC
Have you tried logging with tephra's app instead of Evoscan? By doing this you can tell if the problem is with Evoscan. If tephra's app gives you the same logs then the problem maybe with your cable or ECU.
Old Jan 3, 2010 | 01:27 PM
  #876
boostin20's Avatar
I'm not sure what you're talking about with tephra's app. If I can read/write to ecu with ecuflash and in evoscan log with just "evoX" ecu selected, do you really think the cable/connector or ecu is to blame?
Old Jan 3, 2010 | 01:54 PM
  #877
SiC's Avatar
SiC
This is actually the tephra application thread that you are posting on. Read the first post and you can download the application there.
It's hard to say what your problem is with little info that you posted, that's why the first step is to confirm that Evoscan IS infact the problem.....
Old Jan 3, 2010 | 02:47 PM
  #878
boostin20's Avatar
First of all, SIC thanks for helping me out. I downloaded and logged a quick trip down the street with tephra's logger. Below is what came out of it. I tried to attach it, but the attachment restrictions are retarted. I put a screenshot below. there's another 18 pages, but the two left rows only show up.
It makes me think there's an issue with the tactrix connector (switched usb cables-no difference), but the whole ecuflash still working for reading/writing is confusing me.
Btw, since you're saying I'm not giving much info to help troubleshoot, tell me what I need to provide, and I'll be glad to post anything up.
Old Jan 3, 2010 | 03:42 PM
  #879
SiC's Avatar
SiC
Okay, so now it seems like the problem is either hardware related or something may be wrong with your ROM. Did you recently change anything in your ROM prior to this?? Something may have disabled mode23 logging by changing one of your maps.
Try this, backup your current ROM and get a clean virgin ROM of the same ROM ID. Enable mode23 in the virgin ROM and write it to your ECU. See if you can log correctly, if all is well, there maybe something you changed in the ROM that disabled mode23.
Old Jan 3, 2010 | 04:02 PM
  #880
boostin20's Avatar
Okay, I'll try it tomorrow with a gunzo 93 tune. I need a new battery, and I'm scared voltage will drop while flashing and brick my ecu. I'm getting the battery tomorrow, and will also hook up my new battery charger in flashing mode. Btw, I didn't change anything at all in the rom. I've had the same rom for 3 months and logged many times without issue. I'll post up my results.
Old Jan 3, 2010 | 05:50 PM
  #881
nj1266's Avatar
So I am looking at the ActiveWGDC Correction RequestID for the 2008 Evo X. The Wiki Says that the ID is at row 8 column B, but that loaction gives an 80876D. However, the Evoscan Data.xml shows 808B51. I have logged WGDCC with it successfully.
Is the location that the wiki gives for WGDCC incorrect?
Old Jan 5, 2010 | 09:56 AM
  #882
boostin20's Avatar
I got my battery and flashed with a new map no previously saved on my computer. Mode 23 worked after that. Thanks, for the help SIC.
Old Jan 8, 2010 | 07:15 PM
  #883
Koroshiya's Avatar
tephra clear your PMs so I can send you one. Your inbox is full!
Old Jan 9, 2010 | 09:04 AM
  #884
mrfred's Avatar
He hasn't cleared his inbox in the last year.
Old Jan 9, 2010 | 10:48 AM
  #885
E6-X's Avatar
tephra is a busy man ... LOL .. good to know some how to ....
