Evo X Logging
Old Dec 12, 2010 | 07:16 AM
  #1021
Golden's Avatar
Also, beings that this is the logging thread....
I have defined a huge chunk of addresses for the 2011 RA. They are still out for testing, but if anyone needs the addresses let me know. There is no reason to re-invent the wheel.
Old Dec 12, 2010 | 07:31 AM
  #1022
Jumperalex's Avatar
Golden, thanks for the follow up. Razor pointed me to your thread on the other forum for your evoscan defs. You know, the thread I think I have even posted in and pulled ecuflash defs from. Somehow I missed that you had what I needed for Ecoscan right there :O
FWIW and in my defense a little, the selection window in Evoscan is so small all I could see was "Mode23 2010 USA RA", you can't see the bit that also says EVOX. Though looking at the definition file it becomes obvious. For my own use I added your defs as a new ECU and labeled it Mode23 2010 EVOX RA. So now the RA isn't visible but I don't care since I don't have an RA ;-) Actually I think you labelled it that but in either case it helps.
Old Dec 12, 2010 | 05:12 PM
  #1023
Golden's Avatar
That isn't my label. Hamish did that.
Old Dec 12, 2010 | 06:15 PM
  #1024
Jumperalex's Avatar
haha fair enough ... just admitting that I can't take credit myself for it since it was in the definition already
And in either case you still are well deserving of thanks your work with your database as well as putting up with my pestering shenanigans ;-)
Old Feb 24, 2011 | 08:40 AM
  #1025
Jor-El's Avatar
Ok. new to this. I got my rom id and it is 5237. where do I get the definition for this file?
Thanks. and yes, I searched.
Old Mar 26, 2011 | 02:35 PM
  #1026
Hiboost's Avatar
2011 Evolution X USDM 5MT
ECU: 56890007
How do I get full logging on the 2011 working with EvoScan? It seems like all the choices give me partial logging and no proper load values. I'm trying to use EvoScan 2.8.0005 and in windows 7 I can't even find the Datasettings folder that was there for the 2.7 version.
For some reason the search engines are having issues looking this up or there are a total of zero people trying to log with EvoScan on a 2011 which I find hard to believe!
So far the EcuFlash side is working great and many thanks to Golden for the consistant and standardized looking definition files.
Now I just need logging to tweak things a bit more closely, thanks guys.
Old Mar 26, 2011 | 07:07 PM
  #1027
Golden's Avatar
Your data settings are in your "my documents" folder.
Here is my list of logging items for 56890007:
Code:
23808780	2ByteRPM
23808752	PSIG / Boost
23808A87	Knock Sum
238088D4	STFT
23804573	LFTF Idle
23804575	LTFT Cruise
238088E5	LTFT in use
238087AE	Load (MIVEC) and (Timing if IAT GT 75F)
23808731	TPS
23809625	Accel Pedel Position
23808A43	TimingAdv
23808B91	ActiveWGDC
2380868F	Intake Air Temp
23808673	Coolant Temp
23808695	Manifold Air Temp
2380AB1C	IPW
23808FA4	MAF Volts
23809546	INVVT (Target)
23809552	EXVVT (Target)
2380957E	INVVT (Actual)
2380958A	EXVVT (Actual)
23808823	Speed
23808727	Battery
2380AAE1	Barometer
23808A8D	knock_adc_processed
2380AB13	knock_base
2380AB0F	knock_var
2380AB15	knock_change
23808A9B	knock_dynamics
23808135	knock_flag
238086A1	Front O2
238086A5	Rear O2
238045C5	Cruise Light
23808B8F	WGDC Correction
23808817	MAF Hz
Old Mar 27, 2011 | 08:47 AM
  #1028
Hiboost's Avatar
Cool, I'll give those a spin by creating a 2011 ECU definition in that Mitsubishi EvoX Mode23 USA file. I'm assuming that Fuel Load hasn't been found yet, is there a method besides trying to log 100 different RequiestID locations to see what it might be?
I have no idea why my v2.8 DataSettings folder doesn't exist but indeed it is using a v2.7 one even though I never installed that version on this laptop. That certainly threw me off from finding it since I figured that was a backup of my previous settings before I wiped and loaded Windows 7.
If you ever post a standardized XML set similar to how you did the ECUFlash ROM defs I'm sure people would be very gratefull!
Old Mar 27, 2011 | 06:58 PM
  #1029
RazorLab's Avatar
Here you go, some of them might be out date or missing so cross reference golden's post above.
Code:
    <ecu name="Mode23 2011 USA RA EVOX">
      <Mode2 name="Mode2" type="Data List Items">
        <DataListItem DataLog="Y" Color="" Display="2-Byte RPM" LogReference="2ByteRPM" RequestID="23808780" Eval="3.90625*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor=".1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Load" LogReference="Load" RequestID="238087A8" Eval="x*10/32" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="30" ScalingFactor=".1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="TimingAdv" LogReference="TimingAdv" RequestID="23808A43" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-10" GaugeMax="50" ChartMin="-10" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Barometer" LogReference="Baro" RequestID="2380AAE1" Eval="x*0.07251887" Unit="psi" MetricEval="x/2" MetricUnit="kPa" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="50" Visible="False" />
        <DataListItem DataLog="Y" Color="#4b0000" Display="PSIG" LogReference="PSIG" RequestID="23808752" Eval="(x/4*0.1953125)-[Baro]" Unit="PSIG" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-15" GaugeMax="35" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Knock Sum" LogReference="KnockSum" RequestID="23808A87" Eval="x" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Accel Pedal Position" LogReference="APP" RequestID="23809625" Eval="(x-32)*129/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="TPS" LogReference="TPS" RequestID="23808731" Eval="x*100/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Active WGDC" LogReference="WGDC_Active" RequestID="23808B91" Eval="x/2" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="IPW" LogReference="IPW" RequestID="2380AB1C" Eval="x/1000" Unit="ms" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Manifold Air Temp" LogReference="MAT" RequestID="23808695" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="2" GaugeMin="-10" GaugeMax="200" ChartMin="-10" ChartMax="200" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Coolant Temp" LogReference="ECT" RequestID="23808673" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Intake Air Temp" LogReference="IAT" RequestID="2380868F" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Intake Air Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Speed" LogReference="Speed" RequestID="23808823" Eval="x*1.243" Unit="mph" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="250" ChartMin="0" ChartMax="260" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="STFT" LogReference="STFT" RequestID="238088D4" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT idle" LogReference="IdleLTFT" RequestID="23804573" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT Cruise" LogReference="CruiseLTFT" RequestID="23804575" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT In Use" LogReference="CurrentLTFT" RequestID="238088E5" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Front Oxygen Sensor" LogReference="FrontO2" RequestID="238086A1" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Rear O2" LogReference="O2Sensor2" RequestID="238086A5" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Battery Level" LogReference="Battery" RequestID="23808727" Eval="0.07333*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="InVVT (target)" LogReference="InVVTtarget" RequestID="23809546" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="ExVVT (target)" LogReference="ExVVTtarget" RequestID="23809552" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="InVVT (actual)" LogReference="InVVTactual" RequestID="2380957E" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="ExVVT (actual)" LogReference="ExVVTactual" RequestID="2380958A" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAF Volts" LogReference="MAF" RequestID="23808FA4" Eval="x/1024*5" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAF Airflow" LogReference="MAFgs" RequestID="23808FA4" Eval="x*0.02" Unit="gs" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="#90ff00" Display="External Wideband A/F Ratio" LogReference="WideBandAF" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="10" Notes="Plug in your serial port from your wideband oxygen sensor if you have one." Priority="1" Visible="False" />
      </Mode2>
    </ecu>
Old Mar 27, 2011 | 07:27 PM
  #1030
Golden's Avatar
I've been thinking of doing an EvoScan side of the site.
Old Mar 28, 2011 | 08:30 PM
  #1031
merlin.oz's Avatar
some help please,
I can work out where most ram addresses are on the AUS cars, except the MIVEC addresses.
Can I get some clue as to the address relative to one of the MUT locations.
I am guessing there is some offset to one or more locations.
Old Mar 28, 2011 | 09:33 PM
  #1032
Golden's Avatar
Tell me the rom id, and I'll tell you the address.
Old Mar 28, 2011 | 09:46 PM
  #1033
merlin.oz's Avatar
atm looking for:
53040010
53050012
53610010
52200010
53780004
Old Mar 29, 2011 | 06:32 AM
  #1034
Golden's Avatar
Here you go...
The order is in:
INVVT (Target)
EXVVT (Target)
INVVT (Actual)
EXVVT (Actual)
53040010
53050012:
23809422
2380942E
2380945A
23809466
53610010:
2380943A
23809446
23809472
2380947E
52200010:
23809348
23809354
23809380
2380938C
53780004:
2380937C
23809388
238093B4
238093C0
Old Mar 29, 2011 | 09:06 PM
  #1035
merlin.oz's Avatar
thanks Golden, I will test some tomorrow.
