Evo X Logging
Old Jun 4, 2009 | 07:27 PM
  #91
tephra's Avatar
Originally Posted by SiC
Oh and WGDC Correction is MUT8B 0.5*x-64
So in the config.txt it should look like this on the 52680018:
WGDCCorrection:0x80876D:1:x,0.5,*,64,-:2
SiC - I think 8A/8B are "overriden" by MrFred for this exact purpose.
You would need to look at the Turbo_Calcs code to get the right memory addresses.
I can help if its super necessary, I really never needed to use it for CT9A
Old Jun 4, 2009 | 08:02 PM
  #92
SiC's Avatar
SiC
Ah, okay that makes sense. I don't really use it either because I use aftermarket boost controllers most of the time.
BTW, is MUT2C airflow volume? The other things I was looking for was intake air temp & engine coolant temp but I couldn't get the right MUT (tried MUT07 & 3A but they weren't correct).
Old Jun 4, 2009 | 08:36 PM
  #93
tephra's Avatar
MUT 10 and MUT11 for IAT and Cooltemp. (both x-40 scaling)
With the MUT's they *should* be the right thing - but obviously not always correct (ie fuel trims)..
its a case of trial and error
Old Jun 4, 2009 | 08:53 PM
  #94
SiC's Avatar
SiC
Thanks, I'll give it a shot
*Edit*
Confirmed that they are both correct!! Thanks again!
Old Jun 4, 2009 | 10:00 PM
  #95
tsitalon1's Avatar
So why isn't this in EvoScan again?
Old Jun 4, 2009 | 10:08 PM
  #96
onboost's Avatar
SiC,
have you got this working for the JDM's?im keen to try tonight
Old Jun 4, 2009 | 10:34 PM
  #97
SiC's Avatar
SiC
Originally Posted by onboost
SiC,
Yes, working
Old Jun 4, 2009 | 10:47 PM
  #98
tephra's Avatar
it will be ... eventually
Old Jun 5, 2009 | 03:52 AM
  #99
onboost's Avatar
tephra,
are you able to help me start on this? im not completely sure on how to modify xml's etc but i want to log knock sum and a couple of others as SiC modifyd my rom for me PM me if you want if its easier
Old Jun 5, 2009 | 04:23 AM
  #100
SiC's Avatar
SiC
tephra,
Onboost, just send me the ROM & XML, I'll mod it for you
Old Jun 5, 2009 | 04:37 AM
  #101
onboost's Avatar
should be in your email now
Old Jun 5, 2009 | 04:48 AM
  #102
tephra's Avatar
what romid u dealing with OB?
Old Jun 5, 2009 | 04:52 AM
  #103
SiC's Avatar
SiC
He's using 52360018, he just sent me the ROM
Old Jun 5, 2009 | 05:13 AM
  #104
SiC's Avatar
SiC
The Mode23 enabled ROM should arrive at your door step right around now
Old Jun 5, 2009 | 08:30 AM
  #105
e_leo's Avatar
When i run the mod 23 logger v1.1a i get the message in dos prompt:Error-there is a problem with your OP2 dll's...Any ideas?
I run xp pro 32 sp3
