Virtual Dyno Room-Dyno Simulator
Old Dec 24, 2010 | 06:17 AM
  #1306
BEZ-01W's Avatar
Lucky Logic's Mirror works, because the versions on the front page have issues with car selection. downloaded from the mirror above.
Cheers
Bez
Old Dec 24, 2010 | 09:37 AM
  #1307
Jack_of_Trades's Avatar
I updated the link in the first post with the mirror site,thanks
The full stand-alone will most likely launch this spring when racing season starts back up.
Old Dec 25, 2010 | 06:12 PM
  #1308
BEZ-01W's Avatar
The standalone sounds good. Maybe we could port to iPhone and iPad.
I am looking for a project to do while I learn the coding for the platform.
Cheers
Ben
Old Sep 23, 2011 | 04:20 PM
  #1309
YaroRS's Avatar
guys, can you advise me, I am using 5.71 VDR, based on Excel, what dyno correction should I apply, so it would be as close as possible to real WHP ?
P.S. Sorry if it has been discussed before
Old Sep 23, 2011 | 09:03 PM
  #1310
Raptord's Avatar
There is no "real" whp. It all depends on which kind of dyno you'd like your figures to resemble. If I'm not mistaken, 1.09 is close to a mustang dyno and 1.12 is close to a dynojet. Nevermind, I am mistaken; see below
Old Sep 23, 2011 | 09:36 PM
  #1311
chetrickerman's Avatar
Veteran: Army
.95 is mustang, 1.09 is dynojet. according to Virtual Dyno
Old Sep 24, 2011 | 05:24 AM
  #1312
Raptord's Avatar
Thanks Chet, edited my post.
Old Sep 24, 2011 | 05:37 AM
  #1313
bbarnhill's Avatar
Those correction factors are true in Virtual Dyno but that is a different piece of software than this and it has different correction factors than VDR. Just making sure that everyone knows they are different and written by different people.
Old Sep 24, 2011 | 10:05 AM
  #1314
Raptord's Avatar
Ah ok, I knew those were the numbers from VD, I figured they were the same in VDR
Old Sep 24, 2011 | 10:17 AM
  #1315
Veteran: Army
No problem
Old Oct 15, 2011 | 07:02 PM
  #1316
jonmorera's Avatar
From: Costa Rica with business addres in Miami FL 33166
Hi guys!!! I have a problem with this program, I can't do a good dyno, I'm doing something wrong, the program shows excessive hp and torque.
This is my log file maybe someone can check:
https://www.evolutionm.net/forums/at...tor-jonlog.zip
Old Oct 15, 2011 | 07:20 PM
  #1317
Raptord's Avatar
Tried your log on my end, works fine. Have you tried re-installing?
Old Oct 15, 2011 | 07:54 PM
  #1318
jonmorera's Avatar
yes I tried re-installing and with others versions and the same problem.
Old Oct 15, 2011 | 09:37 PM
  #1319
bbarnhill's Avatar
shouldnt matter if you installed with a previous version as it will auto update to the latest version. I just graphed it as well and it looked fine to me.
Goto Start -> Control Panel -> Region and Language -> Make sure its set on English (United States) and see if that helps.
Old Oct 15, 2011 | 10:10 PM
  #1320
evonewb29's Avatar
hey jonmerera,
I had the same problem too when i was trying to import a long data run. If you drive around for a few minutes logging before you get to make your pull, the numbers would be strange if you try to import the run as a whole ( this is at least what i found). I would just go back through evoscan, locate the time of the pull, and than copy and paste only the run data into the simulator when viewing the log in exell. It worked fine everytime since. too much data confuses the program
