Virtual Dyno Room-Dyno Simulator
I did my first shakedown pass with the 1990 4G63 powered Mirage Hatch I got with a 60-1 Turbo and now with an EVO 8 ECU in her with an Evo 8 knock sensor. It was at low boost and insanely low timing since it was my first pass to dial-in the AFR. Not bad for a base to work off of. That 60-1 turbo responds like a GT35R....so laggy. It'll probably come in handy when I start launching this thing though.
bumped the boost up to 44psi on the stock ecu/mas hta86 and the torque came alive but the hp not so much. This is with 1.12 correction factor to match the dyno I hit in Kansas where I did 703/539 previously. Seems I'm hitting a choke point...maybe mas, maybe intake (stock ported)
Try giving that some more smoothing.. Id like to see it smoothed out some... that thing is like a roller coaster hehe.
i try and smooth mine till it looks smooth without humps. I did some pulls today as well. It was a little cooler out today but I JUST filled up my tank and was on the way home so i did some pulls. I didnt add any extra weight for the gas as i have no idea how much to add lol. I will post it up for u in a sec.
Mellon I garuntee ur MAF is starting to become a big restriction on 44psi on the HTA86. My maf was a restriction on just my 35R at high boost levels especially the higher RPM it went it would fall off like im seeing yours do on that graph.... and we seen this on the dyno jet up at AMS.. I went to AEM because of that and the driveability factor... But mainly for the power of the speed density setup so i could eliminate that tiny hole the maf breaths through and throw a 4inch intake on
i try and smooth mine till it looks smooth without humps. I did some pulls today as well. It was a little cooler out today but I JUST filled up my tank and was on the way home so i did some pulls. I didnt add any extra weight for the gas as i have no idea how much to add lol. I will post it up for u in a sec.Mellon I garuntee ur MAF is starting to become a big restriction on 44psi on the HTA86. My maf was a restriction on just my 35R at high boost levels especially the higher RPM it went it would fall off like im seeing yours do on that graph.... and we seen this on the dyno jet up at AMS.. I went to AEM because of that and the driveability factor... But mainly for the power of the speed density setup so i could eliminate that tiny hole the maf breaths through and throw a 4inch intake on
I prefer to have the smoothing lower so I'm not masking flaws in the tune. I looked at my log and sure enough it's a little leaner in that spot, clearly the car likes more fuel so I'll be addressing that.
If i put mine at 4 it would be a total roller coaster lol and i am 100% sure my power curve doesnt look like a roller coaster as i have had my car on a dyno jet MANY times.
Here is my VDR i got this evening. I just filled up my tank and didn't add for the extra weight as i have no idea how much extra weight to put in for the added fuel lol. This is using the 1.1 correction factor that is right on with the dyno jet that i use up at AMS for my car. I have checked this by running it right after the dyno pulls within a few hours....IMO this is very important or your VDR will be inaccurate from your dyno if using a custom correction factor! For instance if i used the 1.12 that Mellons has to use to match his dyno jet #s my car reads too high from what it did on the Dyno Jet I use. For reference my 1.12 correction factor put my HP up to 773hp and 565tq.
37.8psi PEAK running E85. A/Fs of mid to lower 12s. Car is liking the cooler night air
very nice, massive improvement over mine at high rpm even with lower boost, shows that I'm shoving boost down it's throat and not getting the return on it except for torque down low.
I bet you would have went faster on 38psi at the track the other night fo sho! IMO Ur car has 9s in it with ease at the 38psi u dynoed it on without a doubt!!
I say with going SD and a good intake ur car will wake up like no other!! Hell my car has a stock valved stock port head.... And with my tune and the combo of parts it holds HP to 9K like its its job
Seeing as Colt4g63 found that 1.10 is perfect for the DJ he uses, and Mellon found that 1.12 is perfect for the DJ he used, its fair to say that a nice average would be a Dynojet Correction Factor of 1.11 at this point until we get more data.
I just realized that the street pull I did with the Mirage was with air flowing thru the stock 1.5" exhaust. The car has a 3" cutout y-pipe where the CAT should go. Maybe tonight I'll do a pull with the cutout :-)
