Virtual Dyno Room-Dyno Simulator
Old Sep 1, 2009 | 11:42 AM
  #586
Colt4g63's Avatar
Man im slow today... more so then normal it seems. Sent!
Old Sep 1, 2009 | 11:43 AM
  #587
Mellon Racing's Avatar
same problem, base is blank with office 2003, didn't work when I unlocked it either FYI
Old Sep 1, 2009 | 12:02 PM
  #588
Jack_of_Trades's Avatar
Found the problem, I will try to have it fixed tonight if I can. For now, try starting your log below 3000rpm when copy/pasting it into the program and see if that helps with the base pull side. It was originally designed to auto-adjust some of the math functions for the RPM portion only up to a certain RPM but now that you BIG turbo guys start your pulls much later, I need to edit the program to go higher up the RPM range.
Old Sep 1, 2009 | 12:06 PM
  #589
nonschlont's Avatar
Originally Posted by Jack_of_Trades
Did you first select "USER CORRECTION 1" from the drop-down list where you choose the dyno type (i.e; Evo-m Comparator,Dynojet,Mustang,etc)?
LOL I had a feeling I wasnt setting it up correctly... I was leaving it on the Dynojet setting, since thats what I was on last.
Got it, and works perfectly, even on the base run.
Great work!
Old Sep 1, 2009 | 12:34 PM
  #590
Aright fella's, I think I got it. Please beta test v5.62 for me before I launch it.
http://dsm-ezine.com/Virtual_Dyno/VDR.v5.62.xls
Old Sep 1, 2009 | 12:54 PM
  #591
Colt4g63's Avatar
Working for me
Old Sep 1, 2009 | 01:07 PM
  #592
work for me too, thanks bud
  #593
nonschlont's Avatar
All good w/ me!
Old Sep 1, 2009 | 07:43 PM
  #594
whoflungpoo's Avatar
Works like a champ!
Old Sep 1, 2009 | 08:12 PM
  #595
Z_Lancer_Man's Avatar
Doesn't work with OpenOffice 3.0.1 (No curves on the dyno graph), running on Ubuntu Jaunty (9.04)
Old Sep 1, 2009 | 08:23 PM
  #596
Yeah, unfortunately right now I'm not even bothering with the OpenOffice aspect of it, hoping that the stand-alone version will be out soon anyhow.
EDIT: I just checked it with OpenOffice version 3.1.0 and it works fine for me. Maybe update your version of OpenOffice and see if that fixes it?
Old Sep 1, 2009 | 10:34 PM
  #597
With some tweaks I got it working - OOO 3.1 helped, also adding a ' in front of the 06 Evo 9:5-Spd worked.... now I just need to figure this whole ecu direct boost control thing....
Old Sep 2, 2009 | 01:04 AM
  #598
onboost's Avatar
does it have the evo x Cod?
Old Sep 2, 2009 | 04:52 AM
  #599
Not yet, if anyone happens to find a reliable source for the FRONTAL AREA and Drag CoEfficient for the Evo X, please post up a link!
Old Sep 2, 2009 | 05:45 AM
  #600
I'm FINALLY getting some free time to breathe.......so......I've decided to change my gameplan a little bit to accommodate just about ANY vehicle without having to constantly add vehicles to the list. This program will only come with Evo 7-10's as the default Vehicles since that was its original purpose (and so users know that the Evo community created this tool). I will create a VEHICLE LIST page that will hold the following columns of data for each vehicle.
  • Vehicle/Transmission Type
  • 3rd Gear Ratio
  • 4th Gear Ratio
  • Final Drive Ratio
  • Frontal Area
  • Drag CoEfficient
There will be roughly 10 blank spaces where users can add their own vehicle info (and save it) to the list so ANY vehicle type can make use of this program. The items added to this list will appear in the 'Transmission Type' drop-down list on the Dyno Graph.(which I will be renaming 'VEHICLE TYPE') Below is just a rough example:
This will also eliminate the need for the USER OPTION for different gear ratios on the USER SETTINGS page.
