Virtual Dyno Room-Dyno Simulator
It is VERY possible that you are fairly close to those HP levels with your mods. The Dynojet data isn't as 'confirmed' as the mustang dyno #'s are at this point, just need more datalog files from people that got logged just after their dyno pulls on a DJ. Get your car weighed and then use the Mustang Dyno choices and you should have some pretty accurate dyno simulation numbers!
I will look into the Dyno Correction Options not working in OpenOffice, you are running VDR version 5.71 correct? Also, make sure you increase your 'MAX RPM TRIM' if it seems like its not diplaying your entire RPM range of your pull. Its not supposed to stop at your peak power, it should display the entire pull.
Yes 5.71, My max trim is set at 7200 right now, kinda wierd all the pulls is the graph stop right at max power and torque lol. Good work regardless as I am mostly just interested in my max power althought its still nice to see how it goes after that
Yeah, I bumped the DJ correction up to be closer to some ACTUAL DJ data I collected (though I prefer more). I definitely will make a list of stock curb weights and tire diamters to add to this for now. I wanted to make it automatically enter the weights and tire sizes into the blank boxes if that vehicle is selected off the list but I don't know how to have Excel do that and allow the user to change that value manually in the same box. Believe it or not, I'm still VERY new to the Excel world
I'm learnin' though!
All of you OpenOffice users, I just fixed the drop-down problems for you, so REDOWNLOAD V5.71 please.
I don't calculate it. I went from data found online. I usually won't use a value unless I've confirmed with with a minimum of 2 totally different sources, or straight from the car manufacturer. Even if its off a little, as you can try, the difference it makes is probably about 0.33%
God no,lol. This is just me trying to make the current version better until the stand-alone is completed. I'm not the one working on the stand-alone version so IDK how long it could take to come out, anf I finally found free time to work on this again so I figured I'd finally fix the bugs in it.
I've got a run I made ~ 2 hrs after I pulled off of a dynojet. I'd be more than happy to send you the dyno sheet and a copy of my vdr file.
really, it'd be more useful to have a log of an actual dyno run. I'm trying to get a copy of mine.
I just loaded a few pulls in OpenOffice with no issues. If you aren't running OpenOffice version 3.1.1 I suggest updating it by clicking the HELP tab on the top and selecting "Check for Updates". If you are running that version or the problem persists, save a copy of the simulator with your pull pre-loaded in it and email it to me (my email is listed above in this post).
Ok I think I might have an idea. I have been graphing old pulls from when I ws using mitsulogger and for some reason they all were cut off. However today I did some new pulls using my evoscan and they are showing up just fine. Wierd but it is what it is not sure why it would do that but I dont use mitsulogger anymore anyways, Once again great work JOT!!!
A pull on a dyno jet would read differently then on the street i would think since its a toally different load.
Best way IMO is to run on a dyno jet then right after go to a COMPLETELY FLAT road and do a few runs then compare. Thats how i did it with the VDR and its very accurate when it comes to uncorrected #s. VDR FTW no more having to travel and pay to get #s
BTW just sent you a donation. $ is very tight right now so i will have to send some more at a later date. This software is great and VERY consistent and i dont mind throwing donations at all. I know you have put a lot of work into it and its greatly appreciated!
PS. It came from my business email AB Mods.
Best way IMO is to run on a dyno jet then right after go to a COMPLETELY FLAT road and do a few runs then compare. Thats how i did it with the VDR and its very accurate when it comes to uncorrected #s. VDR FTW no more having to travel and pay to get #s BTW just sent you a donation. $ is very tight right now so i will have to send some more at a later date. This software is great and VERY consistent and i dont mind throwing donations at all. I know you have put a lot of work into it and its greatly appreciated!
