Virtual Dyno Room-Dyno Simulator
Old Oct 11, 2009 | 08:38 PM
  #736
B NEAT's Avatar
OK, we'll stay on topic. Will Virtual Dyno tell you your E.T. based on 20+ car lengths in front of a car that ran 11.14 @ 128 with a 2.2 60'?
I'm ordering the Supra emblems in the morning.
Old Oct 11, 2009 | 11:09 PM
  #737
Jack_of_Trades's Avatar
Originally Posted by Colt4g63
Ok so this is Jacks thread " a very good and informative one at that" so lets not turn it into a shat talking fest like the local crap forums around here.
Should I paypal you the MAID fee's for keeping things tidy in my area? lol
Old Oct 12, 2009 | 05:39 AM
  #738
recompile's Avatar
Originally Posted by Jack_of_Trades
Look for test results with power curves of engines on an engine dyno, then installed in a car on a chassis dyno. The power curves are almost identical except the chassis dyno's #'s are lower obviously. This shows that the drivetrain losses are generally consistent throughout the power curve. The higher the HP output, the larger the difference between the engine dyno and the chassis dyno....so you can't just add or subtract a specific #. It's a PERCENTAGE of power loss, not a set amount.
If the entire curve stays the same, only moves down -60 hp, how does that prove it's a percentage? It doesn't, it just means the curve has shifted due to drivetrain loss... a loss that could just as easily be described as a static number of -60 hp (throughout) instead of -25% (throughout)
The argument that it's a percentage loss doesn't make sense to me, because basically you're saying:
1) Say it takes 75 hp to operate your drivetrain on a 300 bhp motor
2) Swap a big turbo to make 600 bhp
3) That same exact drivetrain now somehow requires 150 hp to operate?
It doesn't make sense. In the real world and not the paper world, drivetrain loss is not EXACTLY a static percentage NOR EXACTLY a static number, but personally, I think using a static number is much more accurate, especially when you're talking about highly modded, big horsepower cars. It's absurd to think that a 600 whp Evo is losing 200 hp due to drivetrain losses.
Old Oct 12, 2009 | 07:48 AM
  #739
sponners's Avatar
The more force that is applied to bearings, components, tyres etc the more energy gets sapped up by them.
so it is definately not a fixed hp number.
Old Oct 12, 2009 | 08:56 AM
  #740
B NEAT's Avatar
Agreed, but it's not a set percentage either. Imagine bolting a 10,000 hp motor to the same drive train. It'll take a smarter person than me to figure out what the fomula is to solve this, but I'm sure it's do-able.
Old Oct 12, 2009 | 10:49 AM
  #741
Guys, don't try to hurt your brains here. It's been proven decades and DECADES ago that it IS 10000% in FACT a PERCENTAGE!!!!!! People have taken a stock engine and dyno'd it, then tossed in in a car and had a specific PERCENTAGE loss. Then took ANOTHER super high HP engine off a engine dyno and bolted it up to the EXACT same drivetrain and had the exact same drivetrain percentage loss. Period. The percentage amount may change throughout the power curve but the percentage 'curve' is a constant. Do some research here, don't just argue your theory blindly just because you don't believe it.
Start with Supra's, definitely a good example. a 1400hp built engine only does about 1100-1150hp to the wheels, the same percentage the stock engine does through the same drivetrain basically.
Old Oct 12, 2009 | 10:51 AM
  #742
GST Motorsports's Avatar
It is evom after all.
- Bryan
Old Oct 12, 2009 | 10:53 AM
  #743
- Bryan
lol, maybe you can shed some light on this for these guys since you are a WHP professional haha.
Old Oct 12, 2009 | 11:33 AM
  #744
Bosshog's Avatar
well if you disagree with my comments / observation, I would appreciate your input instead of making a useless post. I for certain know that dastek and vamag dynos used in Europe do not have constant multipliers. Now, the same might not be true for DD, Mustang or DJ but I have no idea. Maybe this is where you can enlighten us
- Bryan
Old Oct 12, 2009 | 11:59 AM
  #745
If you guys don't mind, I would rather that you start a new thread for this discussion because I can see this taking up a lot of pages and I want to keep things on topic for this thread. Thanks fellas.
Old Oct 12, 2009 | 06:14 PM
  #746
Colt4g63's Avatar
When ur car ran that I put down 443WHP and would put 1-2 cars on you in a street race. You do the math you say my car has to be putting down minimum of 800WHP by your estimates so you should be a good judge
Mr BNeat Track guy here that's taken his car to the track 1 time in 9 years of owning it
Old Oct 12, 2009 | 06:15 PM
  #747
Colt4g63's Avatar
You got my paypal you can go ahead and send some $s my way
Old Oct 14, 2009 | 05:10 PM
  #748
downshift411's Avatar
ok how do you guys use this again?
Old Oct 14, 2009 | 05:15 PM
  #749
Open your 3rd gear pull datalog (or 4th gear) with Microsoft Excel (or OpenOffice Calc), copy the 'LogEntrySeconds' and 'RPM' data and paste it into the appropriate sections in VDR. Be sure to only copy/paste the data while you were at 100% throttle, nothing else. Then just fill out all of the info for your particular vehicle.
Old Oct 14, 2009 | 06:37 PM
  #750
ok now i understand the concept and using the excel file. my concern is, i do have saved logs but i think their just shortcuts instead of the actual file. in evoscan i think its only save into a temporary file in which evoscan can open with. i tried opening them with the excel but they're giving me an error saying my log"xxx" does not exist. i have the sample logs that came with evoscan. those open up with the VD file...i dont get it?
