Virtual Dyno Room-Dyno Simulator
Can you be a little more specific? The Base pull or the comparison pull? Which vehicle selection are you using?
Both base and comparison. I use metric setting, and whatever veichle I select (also the user defined veichles if i put in one) if I select 4th gear the dyno graph disappears and show zero for power and torque.
EDIT, I tried the imperial setting, the base pull is OK, the comparison give the same problem
Don't hold your breath on more than 2 pulls being loaded at once. It takes a great deal of space just to have 2 pulls setup currently. We want it to be easy to use while not having it appear too "busy" on the screen. Once the beta testing is done on the stand-alone version I'm sure we can see how involved it will be to add the other features though.
nice i cant wait! so wats the major dif between the standalone vs the exel version? beside the fact we wont need excel? also what smothing do you recommend? i use to use the default 12 but i found 10 and 7 better it actualy showes were my turbo falls off it power band. should we just go for prefrence?
Anyone have this problem?
As you can see I paste my datalog into the cells and this is what it gives me??? I have redownloaded vdr a couple times and it might give me a whole graph the first time I paste and maybe a second then it does this any ideas why?
Did you only copy/paste only the portion of the pull while at WOT? If you email me that log, i can see if i can find the error for ya. (PunkDivo78 at hotmail dot com)
I had it once. Delete and re-install a new VDR on your computer.
I have done that twice with no change
. As far as sending you the log its not one specific log that does it. Once it does it once it will continue to do it to every log no matter what. Unless I uninstall and reins or restart the computer. I have noticed something. When I copy and paste each column separately it does not seem to happen as often if at all but whenever I copy both seconds and rpm at once that seems to be when it will do this.
