Virtual Dyno Room-Dyno Simulator
Old May 14, 2010 | 10:37 AM
  #841
03lances's Avatar
Originally Posted by bbarnhill
I have been giving the standalone version away to beta testers with no feedback. Its kind of discouraging to give it away to get feedback and noone responding. I know it needs work but dang I wanted to know if it halfway worked first before I cleaned it up. I guess I could go ahead and display AFR in the bottom graph but I need an evoscan log with afr in it first. My LC1 stopped logging for some dumb reason but it still displays on the gauge.
My offer still stands to do a beta test I am always messing with my car a datalogging.
Old May 14, 2010 | 11:26 AM
  #842
mrfred's Avatar
J_of_T's VDR is built on my Excel HP/TQ spreadsheet, so I'd be happy to beta test your standalone.
Old May 14, 2010 | 11:38 AM
  #843
donour's Avatar
+1
and port it to Mac if I can find a free evening.
Actually, I've already written one application that does this (pyxede), but few people use the Xede anymore...
d
Old May 14, 2010 | 12:20 PM
  #844
nonschlont's Avatar
Im willing to help out as well...
Old May 14, 2010 | 12:22 PM
  #845
hediki12's Avatar
+2
kemist88@gmail.com
Old May 14, 2010 | 02:26 PM
  #846
drb's Avatar
drb
I'd be happy to help with testing. I am always running logs on evoscan and I have used VDR a bunch. I can send you evoscan logs with AFR from an LC1.
Dan (drb)
Old May 15, 2010 | 09:19 AM
  #847
donour's Avatar
This is kind of on topic:
If anybody wants a copy of my python scripts for generating road dyno plots, let me know. They are currently configured to grab MacLogger/Evoscan type csv file, the first large contiguous block of high throttle, then call gnuplot to compare.
d
PS: do you old timers remember this thread:
https://www.evolutionm.net/forums/ge...-inclined.html
that's back when I used to actually *think* about this stuff. It's back.
Old May 16, 2010 | 09:15 AM
  #848
project_skyline's Avatar
I spoke to jack a while back about working to in cooperate this with some other types of vehicles mainly subaru's. I have found that airboy's spreadsheet seems to be pretty limited for the cars it can work for or the gears you can chose.
Anyway he told me about this new program being setup and I was wondering if something that has been implemented or if its something you want to do or need help with? Let me know.
And if you need a tester for the program just send me a pm or email me at my username @ live.com
Old May 20, 2010 | 07:37 AM
  #849
bbarnhill's Avatar
I have a beta test of the program ready but Id like to add a few more features to it before I send it to anyone else ... plus the beta testers I am getting dont send me any feed back. I dont need any more of those beta testers. I need feedback about what works and what doesnt ... features that NEED to be added. Right now I need a log with AFR in it to get the AFR graph woring. If anyone has a log let me know so I can send you my email address to get it to me or post it in this thread. After that gets in there Id be willing to let people test it if they promise to give feedback. This project will never get done with out some feedback. So help your fellow Evo owners and give me feedback.
Old May 20, 2010 | 07:50 AM
  #850
newcomer81's Avatar
Pm'd you a log. forgot to mention its a 2008 gsr 255/35/18 stock weight +215lbs (i'm huskey)
Old May 20, 2010 | 08:31 AM
  #851
03whitegsr's Avatar
One cool feature that could be useful for tuning would be a Brake Specific Fuel Consumption (BSFC) tab. Add a column for IPW on the data entry screen then injector size, latency and base fuel pressure settings on the chart screen. Calculate fuel flow and then BSFC.
Just a thought. It helps show areas of your curve you may be able to pick up additional power or when you reach that point where the motor is no longer efficiently making power.
Old May 20, 2010 | 10:32 AM
  #852
donour's Avatar
Here's one to move you along.
A road pull:
http://www.cs.unm.edu/~donour/cars/e...l/road-log.csv
Ambient pressure was 24.440 in.Hg. Yes, 24. That's not a typo. Temp was about 40 degrees. 04 RS, 3rd gear. 3220 lbs total
A dyno graph, almost back to back:
http://www.cs.unm.edu/~donour/cars/e...comparison.jpg
Enjoy. Hopefully your code will run on something other than windows.
d
EDIT: While I'm chatty, I'll mention that I chose that log for a reason. Notice the plot has a big dip between 5500 and 6500. That's a very important feature to conserve. I have spent a lot of time playing with smoothing filters, trying to get one that both preserves that, but gets the peaks right. I haven't found anything that I'm happy with.
Old May 21, 2010 | 09:26 PM
  #853
bbarnhill's Avatar
Was going to work on this project this weekend while at this 'lovely' wedding weekend extravaganza that I have to go to. BUT ... I left the code back on my desktop. I could kick my own *** sometimes.
Old May 31, 2010 | 07:07 AM
  #854
cij911's Avatar
Guys - how much data do you need to make the numbers / curve look correct ? For example, I noticed in my 3rd gear pulls, I collect a lot less data than what others are seeing and I go from 3K to 8K quicker than others, but m numbers are WAY low. Also, how do I collect more data (increase the sample rate) - others seem to have 2 - 3 x, but I have a brand new laptop. TIA
Old May 31, 2010 | 07:44 AM
  #855
newcomer81's Avatar
first; only collect the data points you need. for instance you don't need to be logging speed unless your trying to find out of your clutch is slipping.
second; make sure your lappy is in high performance mode. often when your not plugged in it drops to a battery saver mode.
