Disassembly: 2-byte variables
Old Jun 22, 2009 | 06:32 PM
Deepnine's Avatar
Hi,
i came accross the adc stuff and the 2-byte stuff. I never cared about that before.
i don't know if i had understood it correct:
1.) all memory adresses are 2byte (word) length, but only the 1byte are used like mut_21 (rpm). But there are adresse, which use all 2bytes. Its not a general rule that only the lower 8 bits are used. 2byte values and 1byte values use the same memory space (always a word).
Right?
2.) Lets say i want to log a memory adress which is referenced in the code at 0xFFFF1234 as a word. i know its only a 1byte value in it.
then my mut table must have 0xFFFF1234+1 = 0xFFFF1235
Right?
3.) now i have a two byte value in a word at 0xFFFF6789.
To log it via mut, i need two mut id's. first 0xffff6789 and second 0xFFFF6789+1
Right?
4.) Where is a free memory adress for my stuff? I don't want to overwrite some memory locations, that are used by large arrays or something like that.
Old Jun 22, 2009 | 09:24 PM
mrfred's Avatar
Answers are listed in your message.
Hi,
Right?
--> Yes, except that both 1-byte and 2-byte values are commonly used throughout the code.
Right?
--> Correct.
Right?
--> Correct except that your example address is not aligned. 2-byte values will always end with an even hex value, e.g., 0, 2, 4, ...
--> If you set up the memory space in your disassem, you should be able to see what addresses are used. You can use anything that you think is unused. Its important to do some searching in the ROM for references to any address that you are considering using. Mitsu used relatively few indirect calls, but there are some in the code, so its important to try to check all the RAM address stacks in the code to be sure that the address you want so use is not already in-use.
neuralcj
Jan 7, 2018 02:50 PM
mrfred
Jul 20, 2016 06:02 PM
Kaveeth
Sep 29, 2014 10:59 PM
Danieln
Apr 15, 2010 05:04 AM
hackish
Oct 7, 2009 10:31 AM
