anyones ecu failed afer reflash????
Old Jul 2, 2009 | 12:12 AM
infini_IV's Avatar
hey just wondering if anyone has ever had an ecu fail days after a reflash, just trying to work out if it is a coincedence or related. i have an evo 7. original rom id 98640014 that 4 days ago i relashed to 90550001 now it appears my ecu is faulty and reading the tps as 70% open even at idle, checked all cables etc. the throttle valve is fully closed and the tps itself measures up ok .5mv at idle and 4.8mv at full throttle. yet when checked on a mut 3 it reads 3000mv and in evoscan reads 70%
Old Jul 3, 2009 | 12:43 AM
infini_IV's Avatar
no one had this happen or possibly offer an explanation
Old Jul 3, 2009 | 07:22 AM
C6C6CH3vo's Avatar
Been reflashing same ecu weekly, sometimes severl times a day, since 2006. ECU works fine and tps always read 1-5vdc properly in LOGWORKS
Old Jul 3, 2009 | 09:30 AM
andrewzaragoza's Avatar
i suggest checking the wiring from the tps going to the ecu.
Old Jul 3, 2009 | 02:10 PM
infini_IV's Avatar
i confirmed it was a failed ecu, have fitted a replacement and is now working fine. obviously im a little wary about reflashing the new ecu, i understand it may have just been coincedence that it failed after the flash, but wondered if there is some differance between the original jdm tps curcuit and the euro ralliart curuit???
Old Aug 1, 2009 | 12:46 AM
infini_IV's Avatar
no ones had a failure after a flash??
Old Aug 1, 2009 | 12:27 PM
todd6027's Avatar
did you try flashing the dodgy ecu again with a stock 98640014 rom and trying it again.
kamote2000
Sep 30, 2016 10:50 PM
evo4mad
May 5, 2015 06:22 PM
Carloverx
13
May 3, 2012 03:30 PM
TSiAWD666
10
Mar 3, 2012 03:15 PM
yellowevo82
Aug 30, 2009 02:31 PM
