How Important is a 3 Bar MAP?
Old Jul 10, 2009 | 10:18 AM
Werd's Avatar
I want to start learning how to tune. And since my car needs one I feel that's an appropriate place to start. I have an AEM WB, Boost Gauge, and a laptop, but how important is it to upgrade to a 3 bar map sensor? None of the tuners I spoke to about getting my car dyno tuned mentioned it so I'm just wondering how necessary it is.
Old Jul 10, 2009 | 10:55 AM
Asmodeus6's Avatar
You want one if you want to use any of the better ecu based boost control toys... ever. Or if you would like to be able to tune a car yourself. I would certainly recommend it.
If the car is being dyno tuned, most likely they will just plug a map sensor in stream somewhere.
But if you are going to want to log / know where the car is / tune it yourself. You want one.
Old Jul 10, 2009 | 11:50 AM
Kracka's Avatar
Only get one if you want to run ECU-controlled boost or want to be able to log your boost for some reason. Overall, not really important at all for tuning as long as you have a boost gauge and know where you're peaking.
Old Jul 10, 2009 | 12:55 PM
Creamo3's Avatar
Unless of course if you have a gauge that doesn't read boost accurately.
Old Jul 10, 2009 | 07:28 PM
Werd's Avatar
I plan on tuning the car myself so I picked up a GM 3 Bar MAP Sensor today.
Old Jul 10, 2009 | 08:15 PM
Asmodeus6's Avatar
This was the right move.
Logging boost > watching a boost gauge
Old Jul 10, 2009 | 08:18 PM
randomevo's Avatar
^^ x2
or want to make sure that your boost gauge is doing its job correctly.
for logging it owns, for tuning, same story.
If you already have the wideband and a laptop, there is no reason not to get one
Old Jul 13, 2009 | 01:32 AM
Fast_Freddie's Avatar
Veteran: Navy
I can tell you this, My profec B spec II reads about 1.5 psi more than the JDM map, so all this time I thought I had been running 26 psi, I was actually reading about 24.6 psi...
Old Jul 18, 2009 | 12:03 AM
Werd's Avatar
I know I saw it somewhere but I've searched all day and can't find the install instructions for the GM MAP Sensor. How do I log with it? I know have to change some info in the ROM but I have no idea what and also what electrical and vacuum connections have to be made for Evoscan to be able to read it's signal?
Old Jul 18, 2009 | 03:13 AM
k20toEVO's Avatar
does this eliminate the need for a MAF sensor? lol i can have a free end borg warner turbo??
