What would happen if I did this.....?
It will turn off the heater also, so make sure you remove the actual sensor before doing so or it will be ruined. I believe you also still need to run MrFred's code (if applicable to your rom) to prevent a CEL for the heater.
Alternatively, you could run the code for the rear O2 sim or a tephra rom that already has it built in.
importjake00
10
Jan 30, 2008 04:31 AM
