Name that Map
Old Jul 17, 2009 | 11:09 PM
Ceddy's Avatar
Name that Map (Purge Duty)
Hello everyone, thanks for a great forum and the loads of info on it.
I've been working on the older H8 ecus, these maps are from a DSM ecu.
I have almost all the 3D maps defined, but these last couple have me stumped.
The code leading up to them test MAF Hz at 50hz and 69hz, and have a bunch of bit tests to decide to use the 7x10 set or the 10x10 set.
They are close to being the inverse to each other.
Has anyone seen any maps like these before? Any ideas what they could be for?
Thanks much.
Old Jul 19, 2009 | 07:18 PM
C130flyer's Avatar
I would post this on DSMtuners.com they might know.
Old Jul 19, 2009 | 08:26 PM
the_mork's Avatar
They wont.
Ceddy is quickly showing himself to be our resident H8 guru at dsmtuners so if he doesn't know what something is then likely the rest of us don't either. The hope is that the evo ecus and the H8 ecus seem to be very similar, we even have lean spool even though it is disabled by default.
Old Jul 20, 2009 | 01:50 AM
merlin.oz's Avatar
If you turn it around a bit it might be ISC stepper motor 3D map, which evos have.
Old Jul 20, 2009 | 05:20 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
They look similar to Purge control duty.
Does the value propagate to MUT_4A?
Old Jul 20, 2009 | 05:50 AM
Appauldd's Avatar
Could they be start and warm up control tables that reference the MAF for a signal?
Old Jul 20, 2009 | 06:18 AM
tephra's Avatar
flipxy
Old Jul 20, 2009 | 02:07 PM
Ceddy's Avatar
Originally Posted by tephra
flipxy
This is the tables in there natural form, I had them "swap x y" before.
I've found a large ISC table already, not sure if there are smaller secondary tables for lower rpms?
The table lookup values are in the "extended" MUT table 1AA, 1AB, 1AC, 1AD.
I will have to follow them farther into the code to see where they end up.
I never thought of the Purge Solenoid. That only operates at lower rpms(less then 4000) if I remember correctly. The two tables could possibly be min and max duty cycle?
A lot of the DSM maps are near exact copys of the EVO maps, guess its not the case with these ones.
Thanks very much for everyones help and insights.
Old Jul 21, 2009 | 02:59 AM
acamus's Avatar
for 88590015 they look alike, but I do not know the scaling.
Code:
	<table name="Purge control #1" category="Purge" address="479b" type="3D" level="1" swapxy="true" flipx="true" flipy="true" scaling="Hex8">
		<table name="Load" address="74fa" type="X Axis" elements="10" scaling="Load"/>
		<table name="RPM" address="74c6" type="Y Axis" elements="7" scaling="RPM"/>
	</table>
	<table name="Purge control #2" category="Purge" address="485d" type="3D" level="1" swapxy="true" flipx="true" flipy="true" scaling="Hex8">
	</table>
	<table name="Purge control #3" category="Purge" address="47ed" type="3D" level="1" swapxy="true" flipx="true" flipy="true" scaling="Hex8">
		<table name="RPM" address="75b8" type="Y Axis" elements="10" scaling="RPM"/>
	</table>
	<table name="Purge control #4" category="Purge" address="48af" type="3D" level="1" swapxy="true" flipx="true" flipy="true" scaling="Hex8">
	</table>
Old Jul 21, 2009 | 04:40 AM
acamus's Avatar
They even appear to be present in X (53040010)
Code:
<table name="Purge control #1" category="Purge" address="59f7f" type="3D" level="1" swapxy="true" flipx="true" flipy="true" scaling="Hex8">
		<table name="Load" address="61b8a" type="X Axis" elements="10" scaling="Load"/>
		<table name="RPM" address="61294" type="Y Axis" elements="7" scaling="RPM"/>
	</table>
	<table name="Purge control #2" category="Purge" address="59ffd" type="3D" level="1" swapxy="true" flipx="true" flipy="true" scaling="Hex8">
	</table>
	<table name="Purge control #3" category="Purge" address="59fcd" type="3D" level="1" swapxy="true" flipx="true" flipy="true" scaling="Hex8">
		<table name="RPM" address="612da" type="Y Axis" elements="10" scaling="RPM"/>
	</table>
	<table name="Purge control #4" category="Purge" address="5704b" type="3D" level="1" swapxy="true" flipx="true" flipy="true" scaling="Hex8">
	</table>
Old Jul 21, 2009 | 11:54 AM
Ceddy's Avatar
Thanks very much Acamus.
I knew there was probably similar maps, mitsu likes to recycle their code.
May I ask why Tephra said "flipxy" before, and you have the flipx and flipy selected?
I tried going through the map lookup routine, to see if the axis are referenced backwards, I didn't see anything obvious, but the lookup routines confuse me most of the time..
mplspilot
Dec 5, 2016 03:29 PM
r4p.t0x
Jun 29, 2014 10:17 AM
RJSP
May 31, 2012 05:31 PM
knochgoon24
Oct 7, 2009 04:57 AM
Creamo3
16
Jan 23, 2009 11:13 AM
