Patch: Force OBD Inspection Pass (acamus, mrfred)
Old Aug 13, 2009 | 10:35 AM
  #61
w evo's Avatar
This is awesome!! and thanks for the 9417008 patch!!
fknlowpsi - did they even do a visual inspection for a cat?? or is your test pipe incognito? haha
Old Aug 13, 2009 | 03:51 PM
  #62
fknlowpsi's Avatar
nope they make u pull in and shut it off then they make u get in this fridge thing lol and the hook up the obd turn the key on and check the gas cap $30 please. and i am passed. i failed the first time cause i didnt have the patch i just cleared the code and the busted me on 3 not ready moniters. greatest patch ever lol
Old Aug 14, 2009 | 04:27 PM
  #63
KleenWhiteMR's Avatar
i tried to use this patch to pass epa testing in illinois and failed. when i applied the patch i checked it with my scan tool and all the monitors were completed with the key on engine off. when i went to the test lane they test the car while its running and the ac, sec air, egr flow, and o2sensor monitors were not completed. when i shut the car off they are completed again. has anyone ran into this issue? does anyone have any input on this?
Old Aug 14, 2009 | 08:10 PM
  #64
logic's Avatar
You have to set the relevant tests to both available (in one table) and passed (in the other).
Old Aug 15, 2009 | 09:50 AM
  #65
Monochrome's Avatar
nvm
Old Aug 15, 2009 | 11:37 AM
  #66
i have all the tests set to available and pass. when the car is not running they all show up as such, but only when running several show up as not completed
Old Aug 16, 2009 | 04:42 PM
  #67
neonglh's Avatar
Just so everyone knows, you ALSO have to turn off the CEL's in combination of this patch. When I use a scan tool, the car shows that the tests are all "OK", but there are still 6 CEL's for no EGR or Evap.
Old Aug 16, 2009 | 06:20 PM
  #68
Monochrome's Avatar
Which ROM?
Old Aug 16, 2009 | 07:08 PM
  #69
neonglh's Avatar
Originally Posted by Monochrome
Which ROM?
Probably any of them, but I am using 0008.
You have to turn off the codes that you get using the parity bits, and then also do this patch to set them as passed.
Old Aug 16, 2009 | 07:35 PM
  #70
redleg225's Avatar
Cool. That answers something I suspected might be an issue. I'll change my map and post if this works.
Old Aug 16, 2009 | 08:11 PM
  #71
Monochrome's Avatar
Just checking but are you sure the codes weren't there before the patch was applied and they just needed to be cleared?
Old Aug 17, 2009 | 07:53 AM
  #72
Jp7's Avatar
Jp7
I live in IL also but I was going to pass just with the defouler trick for no cat.
Old Aug 17, 2009 | 02:29 PM
  #73
neonglh's Avatar
Yeah, I haven't had the stock computer in my car since I flashed it. I run AEM all the time.
Old Aug 23, 2009 | 09:16 PM
  #74
SMOKDU's Avatar
Def a must have... thank you!!
Old Aug 30, 2009 | 11:51 PM
  #75
volks-traitor's Avatar
i can't seem to get this to work on my 88590015. i'm new at this stuff, but have successfully added other tables like the periphery bits etc. i followed the videos as well. anyone have any tips? i've verified that it is saved by going back to the ecuflash rommetadata file and checking after saving and closing. the only things i'm not clear on is should i save as a text document type or look up the metadata file? what encoding should i use? ansi , unicode, unicode big endian, utf-8? maybe i'm just saving to the wrong place?
thanks all
