Enabling mode23 illustrated
Old Jan 12, 2012, 03:09 AM
  #61
Deannn's Avatar
Fixed it, installed 1.42 was using 1.43.300. Copied modified rom 53040007 into 1.42 folder and Options have appeared in 1.42
Old Jul 10, 2012, 05:48 PM
  #62
lan_evo_mr9's Avatar
I just got my new 2012 GSR- yay! Anyways, I wanted to start logging some items to see what's going on in the car's brain. I've got the xml correct with the three options for mode 23- 2 IFmodes and 1 DoMode. I changed the hex bits accordingly and started to log. Well, somethings not jiving correctly because all of my values are really screwed up. At idle, it's reading 125rpms, anywhere from 90 to 240mph (I'm stopped), timing advance is 140, etc etc. What am I doing wrong?
Old Jul 11, 2012, 01:03 PM
  #63
Golden's Avatar
Make sure you are using the right definition file in EvoScan. You can download Golden's EvoScan file from goldenevo.com
It should say on the home page which definition file to use.
Old Jul 11, 2012, 03:14 PM
  #64
You're on the ball man- thanks! The addy's in evoscan aren't the same as in your xml file (V1 EvoX). That worked just perfect- donation on the way
Old Dec 15, 2012, 07:48 PM
  #65
thauto99's Avatar
thank you
Very informative, helped a lot, thank you!
Old Jan 13, 2013, 12:00 PM
  #66
REVOlution X's Avatar
I feel like I'm doing something wrong. My rom is 52680015 and inherits from evo10base. I copied the 3 lines (IF & Do) from under 52680015 -> 52680020 and added it to the evo10base.xml under the Misc section like the picture shows. Saved and closed EcuFlash, then re-opened it. The file now shows the 3 IF and Do lines but there are 2 other things listed there.. mode 23 part 1 and mode 23 part 2 (They were there before any changes were made too). Is this right? Any help is appreciated.
Also, I read someone's comment about adding a config.txt?!? I didn't see that listed on the original post.
Update: I changed the values for IFModes to 0x23 and DoMode to 0x52 and both the mode23 parts changed automatically to enabled. See the Before and After pics attached. I flashed the ECU successfully and all is good.
Attached Thumbnails Enabling mode23 illustrated-evo10base-xml.png   Enabling mode23 illustrated-rom-bin.png   Enabling mode23 illustrated-before.png   Enabling mode23 illustrated-after.png
File Type: bin
Old May 20, 2013, 10:49 PM
  #67
ithinku's Avatar
Not evo x ROM can use it?
ECU ID52510010
Old Oct 16, 2016, 02:51 AM
  #68
Brunex's Avatar
omg,
where did the pictures go?
I'm about to do this but I would love to see the pics, is there a PDF file from this how to?
thanks
Old Sep 26, 2020, 05:17 AM
  #69
nglett's Avatar
Can the pictures for this sticky get reposted?
mrfred
Feb 26, 2022 06:16 PM
madpacket
Feb 16, 2018 07:26 PM
w1ll1ng
Sep 30, 2017 05:18 AM
joat09
Sep 8, 2016 01:20 PM
xPRimNT
239
Jun 2, 2016 10:40 PM
Quick Reply: Enabling mode23 illustrated
