Omni 4 bar MAP sensor ROM compatibility settings for USDM Evo 8/9
Old Feb 4, 2017 | 12:05 PM
  #256
ant_turbo's Avatar
Hey is this ok,, When I go to change the, "MAP Comparison" value from 4.00 to 1.23.
I wont let me input 1.23 when I input 1.23 it goes to 1.24 Is this ok
Thanks,,,
Old Feb 4, 2017 | 12:07 PM
  #257
Klaiceps's Avatar
Thanks,,,
That's fine.
Old Feb 4, 2017 | 04:57 PM
  #258
1UpMoto's Avatar
Originally Posted by Klaiceps
Bumping this back up. Did you buy another Omni 4 bar map sensor or did you replace it with a different one? If you used a different one, which one did you use?
mine just failed also, logged it and its stuck in full vacuum. Idles fine, cruises fine, goes lean in any kind of boost. I ordered an AEM 5 Bar.
Old Feb 19, 2017 | 11:23 AM
  #259
ant_turbo's Avatar
Quick question, After installing the omni4bar I noticed my boost has went up from tuned boost 25psi 3port,, to around 28 psi did i do something wrong
And I also noticed that the Map Sensor Maps are highlighted Blue instead of black
dose that mean that they are not enabled,,
Old Oct 7, 2019 | 06:16 PM
  #260
UrbanSmoker's Avatar
I have my settings for the 8895 rom in post #1, reading about -7 vac on ecuflash. Just installed an aem boost gauge with the 5 bar sensor, I’m reading -13 vac at idle. Car is a stock motor stock mivec cams. Do I need to adjust something to get them to match up? I assume the brand new aem gauge is the corrext one here need these to line up properly
Old Oct 8, 2019 | 10:08 AM
  #261
Project_Broke's Avatar
Are they both in the same units?
Some gauges go to InHg in vacuum.
-13InHg is -6.4ish psi.
So that may be the case.
Old Oct 9, 2019 | 06:58 AM
  #262
both in/hg I believe. Well maybe not. Map on evoscan says psig
Old Oct 9, 2019 | 07:40 AM
  #263
Ian0611's Avatar
Idk about the AEM, but I've never seen the Omni 4 bar show the correct values for vacuum in Evoscan. I've heard others say that it's a limitation of the Omni sensor and I never really cared enough to look beyond that explanation. I've always just gone by what my actual boost gauge says for vacuum.
Old Oct 10, 2019 | 06:52 AM
  #264
I’m thinking you are corrext. Boost matches the AEM gauge by 1 psi so I’ll call it good there
Old Oct 10, 2019 | 01:18 PM
  #265
Evoscan is indeed PSI.
The gauge and MAP match. Just different measurements.
Old Oct 11, 2019 | 08:18 AM
  #266
Originally Posted by project_broke
evoscan is indeed psi.
The gauge and map match. Just different measurements.
Old Dec 6, 2020 | 12:48 PM
  #267
Phantom_Evo's Avatar
Is it still correct to disable to P0069 DTC on ROM 88590015. I just changed to omni 4 bar from stock and threw this code. Is it not possible to adjust the MAF setting so that they correspond to the new MAP sensor? Any known issues in disabling the code?
Old Dec 8, 2020 | 05:15 AM
  #268
Are you running a pre-patched ROM? Or did you change the settings to account for the 4 Bar?
Old Feb 26, 2022 | 06:16 PM
  #269
vr401's Avatar
Hello everyone.
I need help here. I'm trying to use omni 4 bar map sensor in Evo 9 wagon Auto. I've created xml list below and found all MAP fault maps but MAP vs MAF Baro and MAP Comparison are different values to Evo9 and 8 roms listed by mrfred 162 and 4.00v
Anyone know what's the deal here?
<table name="MAP Scaling" category="MAP SENSOR" address="55cc" type="2D" level="1" scaling="uint8">
<table name="MAP Output" address="68c4" type="Y Axis" elements="9" scaling="Volts16"/>
</table>
<table name="MAP Fault Trig: Mid VE Max #1" category="MAP SENSOR" address="297e" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Fault Trig: Mid VE Min #1" category="MAP SENSOR" address="295e" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Fault Trig High VE #1" category="MAP SENSOR" address="2964" type="1D" level="1" scaling="Volts16"/>
<table name="MAP vs MAF Baro" category="MAP SENSOR" address="283c" type="1D" level="1" scaling="uint16"/>
<table name="MAP Comparison" category="MAP SENSOR" address="2838" type="1D" level="1" scaling="Volts16"/>
File Type: bin
tephra
70
Jul 11, 2024 12:59 AM
Benja
Jul 3, 2019 12:42 PM
mrfred
Sep 17, 2017 06:11 AM
joat09
Sep 8, 2016 01:20 PM
rxtec
Mar 14, 2016 09:03 AM
