Omni 4 bar MAP sensor ROM compatibility settings for USDM Evo 8/9
Old Feb 10, 2013 | 12:36 PM
  #196
black_beauty's Avatar
any ideas why mine is logging the value I put in for my atmospheric pressure all the time?
Old Feb 10, 2013 | 12:55 PM
  #197
Dynotech Tuning's Avatar
Either take a screenshot of your settings in evoscan or copy/paste the formula and request ID you are using currently.
-Jamie
Old Feb 10, 2013 | 01:02 PM
  #198
This?
Old Feb 10, 2013 | 02:07 PM
  #199
This?
That should work. Is the value you are logging (-14.4)? If so, try temporarily changing the formula to just "x" and see if its logging any values. Then you know its a formula error and not a signal error coming from the map sensor if it logs some sort of values greater than zero. If it just reads zero with the formula changed to just "x", there is something wrong with the signal coming into the ECU most likely or a parameter in the ROM is wrong.
-Jamie
Old Feb 10, 2013 | 07:02 PM
  #200
it's logging whatever value I put into evoscan... Could my map sensor be bad? I've heard the car will run like crap but mine does not
Old Feb 10, 2013 | 07:11 PM
  #201
In the eval formula box, delete the entire formula and just put X. What does it read when you log?
Old Feb 10, 2013 | 07:51 PM
  #202
^ Reads 0
Old Feb 10, 2013 | 08:06 PM
  #203
Either your MUT TABLE address' are messed up at MUT38 or there is something wrong with the sensor.
Can you post a screenshot of your MUT Table?
Old Feb 10, 2013 | 08:18 PM
  #204
MUT Table?
Old Feb 12, 2013 | 04:20 PM
  #205
?? Like the part I added the definitions to? I copied them exactly and have checked them.
Old Feb 12, 2013 | 04:28 PM
  #206
ReaperX's Avatar
Your MUT Table is an address book that evoscan references when it logs. There address asked to log may be the wrong one in MUT 38. Go to google (only because I have no luck with the search function on here anymore) and type in the following:
evom (your rom id #) mut table
That should get you the information you need. If not, post your rom id and I or someone else can paste in the information you need in your xml.
Old Feb 12, 2013 | 04:54 PM
  #207
? 94170015 rom id
Old Feb 12, 2013 | 06:42 PM
  #208
ReaperX's Avatar
Here's the link to the thread for MUT Table definitions:
https://www.evolutionm.net/forums/ec...ions-here.html
Here is what you need to specifically copy into your xml.
<table name="MUT table" category="MUT" address="38158" type="3D" level="1" scaling="Hex16">
<table name="X" type="Static X Axis" elements="32" scaling="Hex16">
<data>-</data>
<data>0</data>
<data>-</data>
<data>1</data>
<data>-</data>
<data>2</data>
<data>-</data>
<data>3</data>
<data>-</data>
<data>4</data>
<data>-</data>
<data>5</data>
<data>-</data>
<data>6</data>
<data>-</data>
<data>7</data>
<data>-</data>
<data>8</data>
<data>-</data>
<data>9</data>
<data>-</data>
<data>A</data>
<data>-</data>
<data>B</data>
<data>-</data>
<data>C</data>
<data>-</data>
<data>D</data>
<data>-</data>
<data>E</data>
<data>-</data>
<data>F</data>
</table>
<table name="Y" type="Static Y Axis" elements="30">
<data>MUT0X</data>
<data>MUT1X</data>
<data>MUT2X</data>
<data>MUT3X</data>
<data>MUT4X</data>
<data>MUT5X</data>
<data>MUT6X</data>
<data>MUT7X</data>
<data>MUT8X</data>
<data>MUT9X</data>
<data>MUTAX</data>
<data>MUTBX</data>
<data>MUTCX</data>
<data>MUTDX</data>
<data>MUTEX</data>
<data>MUTFX</data>
<data>MUT10X</data>
<data>MUT11X</data>
<data>MUT12X</data>
<data>MUT13X</data>
<data>MUT14X</data>
<data>MUT15X</data>
<data>MUT16X</data>
<data>MUT17X</data>
<data>MUT18X</data>
<data>MUT19X</data>
<data>MUT1AX</data>
<data>MUT1BX</data>
<data>MUT1CX</data>
<data>MUT1DX</data>
</table>
</table>
MUT 38 should be 890B
Old Feb 13, 2013 | 06:38 AM
  #209
Ok i copied all of that into my xml. Where is the MUT 38? EDIT: I see what you mean now, took me a second. 3X then 8. I'm not too technical sometimes. It's right, so it should work now?
Old Feb 13, 2013 | 06:44 AM
  #210
ReaperX's Avatar
3 on the y-axis (vertical), 8 on the x-axis (horizontal)
