Omni 4 bar MAP sensor ROM compatibility settings for USDM Evo 8/9
Old Jan 14, 2011 | 12:01 PM
  #136
Creamo3's Avatar
Originally Posted by 240Z TwinTurbo
I think I have pushed the limits without a tune.
Ninja edit, was reading wrong axis
Old Jan 14, 2011 | 01:45 PM
  #137
240Z TwinTurbo's Avatar
Originally Posted by 97gst_spyder
I did the mod to evoscan 2.8.xxx, its reading 43psi at idle... Haha. Can you post what you typed in?
It was titled JDM MAP before I changed its name. Also, Charlotte is 751 feet so I used 14.3psi for atmospheric pressure.
Here is a good calculator, although it says I need to use 14.22psi for 751ft
http://www.calctool.org/CALC/phys/default/pres_at_alt
Old Jan 18, 2011 | 02:33 PM
  #138
Airboy's Avatar
Just wondering why the left column (Voltage?) goes only to 3.63V and the 2nd column has a large jump in value in the last row from 195 to 255). The data preceding it is pretty linear.
What is in the 2nd column and how is it used by the ECU?
0.51 25
0.90 49
1.29 70
1.68 96
2.07 120
2.46 144
2.85 170
3.24 195
3.63 255
Old Jan 28, 2011 | 03:17 PM
  #139
milford's Avatar
does anyone know what xml i would add to my rom in order to log boost with my omni 4 bar. i am using v796530706. i cant seem to figure what xml i use for that rom as its not listed on the first page. thanks for any help!
Old Jan 28, 2011 | 04:22 PM
  #140
milford's Avatar
bump
Old Jan 28, 2011 | 06:41 PM
  #141
mrfred's Avatar
no changes to the 9653 rom are needed. it just works. make the changes to the evoscan file, and you're done.
Old Jan 28, 2011 | 07:54 PM
  #142
evoVI_PR's Avatar
That's right. Im using ROM 96530706 V7 as well. Installed and plugged in my Omni 4bar, made the changes to Mitsulogger and voila, I'm logging boost and almost ready for speed density! This is great! THANKS, ECU-Gurus!
J
Old Jan 28, 2011 | 08:06 PM
  #143
milford's Avatar
Thank you guys
Old Feb 10, 2011 | 02:08 PM
  #144
06RedRalli's Avatar
Ok I installed my OMNI 4 bar and made all the changes to my 94170015 rom...it's logging boost great and I went through and disabled the egr like told.
Now my issue is that I'm running about half a point lean...would this be due to the egr disable or something else?
Old Feb 10, 2011 | 05:26 PM
  #145
06RedRalli's Avatar
^ Nevermind...I got it...forgot I had a little e85 left in the tank so it's throwing my AFR's off.
Old Feb 23, 2011 | 09:38 PM
  #146
tscompusa2's Avatar
Can someone clear something up for me.. Im tuning a evo 7 on SD and he installed the omni4bar.. i dont see any scalings for the omni 4bar for 96530706. Is there any scalings required for this rom ID or is it not necessary due to the fact it didnt come with a MAP sensor from factory?
Thanks
Tom
Old Feb 23, 2011 | 09:54 PM
  #147
RazorLab's Avatar
Thanks
Tom
Look harder, it's 5 posts above yours.
Old Feb 23, 2011 | 09:56 PM
  #148
tscompusa2's Avatar
ya i just checked and seen it thanks. my bad. mrfred answered a guy a few posts up.
how comes it just works on the 9653? is it because the 9653 came out of a car with no map sensor?
Old Feb 23, 2011 | 09:59 PM
  #149
RazorLab's Avatar
If my memory is correct, yes.
Old Feb 23, 2011 | 10:00 PM
  #150
tscompusa2's Avatar
ok thank you.
