Omni 4 bar MAP sensor ROM compatibility settings for USDM Evo 8/9
Old Aug 6, 2010 | 09:12 AM
  #106
RoadSpike's Avatar
Originally Posted by Mr.Nik
RoadSpike,
Thank you. I understood everything.
Another question: what else can I do with Omni 4 bar sensor and the stock ECU?
By what formula to Evoscan 2.7 to calculate the pressure in the bar?
Speed density conversion, stock boost control.
The formula is on page 1
Old Aug 26, 2010 | 03:49 PM
  #107
PlanoEvo's Avatar
cool
Old Sep 9, 2010 | 12:53 AM
  #108
And's Avatar
And
does any have the values for the 9653x706 roms? i'm assuming they must exist for the SD stuff?
thanks
Andy
Old Sep 9, 2010 | 09:07 AM
  #109
D-VO's Avatar
I thought the same thing, but I found that the ROM is zero'ed out in the map sensor section.
Old Sep 9, 2010 | 09:12 AM
  #110
D-VO's Avatar
Oops! Double post.
Old Sep 9, 2010 | 11:29 AM
  #111
And's Avatar
And
what were the addresses you used?
Old Sep 9, 2010 | 12:46 PM
  #112
D-VO's Avatar
It wasn't about the definitions, but about the scaling for each map sensor. Give me a little bit; its been a while since Ive done it, but I'll find it for you.
UPDATE*
Here read this one:
https://www.evolutionm.net/forums/ec...questions.html
Old Sep 10, 2010 | 12:21 AM
  #113
And's Avatar
And
I have the scalings already but would like to know these if possible for the 9653x706 rom
<table name="MAP Scaling" category="MAPSensor" address="670c" type="2D" level="1" scaling="uint8">
<table name="MAP Output" address="800e" type="Y Axis" elements="9" scaling="Volts16"/>
</table>
<table name="MAP Fault Trig: Mid VE Max #1" category="MAPSensor" address="29d6" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Fault Trig: Mid VE Min #1" category="MAPSensor" address="29b6" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Fault Trig High VE #1" category="MAPSensor" address="29bc" type="1D" level="1" scaling="Volts16"/>
<table name="MAP vs Baro" category="MAPSensor" address="283c" type="1D" level="1" scaling="uint16"/>
<table name="MAP Comparison" category="MAPSensor" address="2838" type="1D" level="1" scaling="Volts16"/>
so I can see what the settings are.
Thanks
Old Sep 10, 2010 | 04:05 AM
  #114
D-VO's Avatar
Ah ok. In that case they are not necessary.
Old Sep 10, 2010 | 04:45 AM
  #115
And's Avatar
And
how come they are not necessary? still would be nice to know if they exist though.
Old Sep 10, 2010 | 05:51 AM
  #116
mrfred's Avatar
the 9653 rom comes from an evo that has no map sensor and no map sensor diagnostics code.
Old Sep 10, 2010 | 05:56 AM
  #117
And's Avatar
And
I thought the map sensor information might have been added for the SD stuff? if not how does the SD know the ranges of the map sensor or is it just assumed that it is 0 - 255 and then the scaling give it to the omni 4bar
thanks
Old Sep 10, 2010 | 06:48 AM
  #118
mrfred's Avatar
thanks
the tables you posted are only obd-ii diagnostics related. the sd patch has a map sensor range table.
Old Sep 10, 2010 | 11:11 AM
  #119
10isace's Avatar
Thanks mrfred!!! I've studied a lot of your post. This, once again, worked perfectly!
Old Sep 10, 2010 | 12:04 PM
  #120
rgar's Avatar
I'm a little confused.... Are the new scalings reflected in the V7 xml correctly?
<scaling name="PSIa8 OMNI4barMAP" units="PSIa" toexpr="x/(4.23*2)" frexpr="x*(2*4.23)" format="%.1f" min="0" max="30.1" inc="0.1" storagetype="uint8" endian="big"/>
is what I have and they seem very different from what I'm seeing here for the omni 4 bar?
