Curing overboost with ECUFlash
Old Sep 6, 2009 | 02:48 PM
kaj's Avatar
kaj
i wouldn't mind seeing the FQ roms. that would be interesting and, perhaps, work well on my car.
Old Sep 7, 2009 | 10:27 AM
wip's Avatar
wip
I'm on a different laptop at the moment, but you can get them from here:
http://www.geekmapped.com/forums/
Old Sep 8, 2009 | 11:13 AM
CPhoenix's Avatar
Originally Posted by wip
Defo not a stock rom.
I can send you the stock roms to compare if you like (FQ340 & FQ360)
Timing looks close-ish to a stock FQ340 though.
Curious why you've disabled the rear O2?
Hi mate - please link me for your stock from however from what I've seen of the 88570008 rom they appear to be the same :S
I've disabled the rear O2 since I dont have one. (HKS Downpipe, Sports Cat & Custom Exaust).
Old Sep 8, 2009 | 11:52 AM
Evo_Jay's Avatar
It wont work well on your car.
Old Sep 19, 2009 | 07:02 AM
CPhoenix's Avatar
Right - I've fitted a manual boost controller, set it by eye to 1.2bar went out for a quick blip and had it cut on me again - I can't be pushing that much load but I don't have any figures yet.
I'll go out again tonight with my Evoscan a log whats actually happening but I'm gobsmacked that I'm still getting this. Have I mis-diagnosed something?
Old Sep 19, 2009 | 08:00 AM
evonut270's Avatar
boost/fuel cut is not all about boost level.have you checked the airflow frequency at where the cut occurs?ill guess around 1600hz by what your describing.
Old Sep 19, 2009 | 12:30 PM
CPhoenix's Avatar
Originally Posted by evonut270
boost/fuel cut is not all about boost level. have you checked the airflow frequency at where the cut occurs?ill guess around 1600hz by what your describing.
I've just done another run - hit 4600rpm this time when it cut - I've included the standard Airflow & 2byte Airflow since they are totally different and I dont know which to trust.
I've switched to using the 1byte load (ignore the 2byte load - something odd going on there).
File Type: zip
Old Sep 19, 2009 | 06:28 PM
tscompusa2's Avatar
did you change your Boost Limit yet? set it to 300% and you wont receive fuel cut.
Old Sep 20, 2009 | 12:30 AM
CPhoenix's Avatar
I already raised max boost limit load 255% and 245% @ 6500,7000rpm.
Theres nothing in the logs to say I'm hitting this limit and I'm very worried about pushing the engine past any safe limits especially if the fueling & timing aren't set up.
Old Sep 20, 2009 | 04:27 AM
tscompusa2's Avatar
so richen it up until its about 11.1~ and pull a few deg of timing...... whats so hard about that? pulling the timing is just a precaution until the a/f gets in a decent range. 13+ a/f at WOT is asking for major problems.
Fastone_evo6
Jan 27, 2012 10:04 AM
F0RSAKEN
Nov 30, 2009 04:30 PM
b16a95eg
17
Sep 17, 2008 04:15 PM
Tuner@Swift
26
Feb 8, 2007 05:18 PM
bigjhoney
Mar 15, 2005 01:45 PM
