Prescision 880cc and scaled to 713 is this not correct?
Old Aug 20, 2009 | 07:57 PM
xspsi4's Avatar
The car pulls good and has less than 3 counts of knock across the rev band but I am getting a lean bank 1 code and all of the searching I have done points to this being the problem and I should mention that I am a newb to the self tune so please take it easy on me if I missed something that is common knowledge
Also if change the scaling then my a/f tune would be off as well correct?
I would post the tune which I have saved but I am unsure how to do that
Any help would be greatly apprecieated
Old Aug 20, 2009 | 08:13 PM
EatSleepBoost's Avatar
o boy. i will let the guru's help you but i would refrain from driving your car lean in the mean time. Did you alter your latency or just change the scaling?
refer to this
https://www.evolutionm.net/forums/ec...injectors.html
Old Aug 20, 2009 | 11:43 PM
GST Motorsports's Avatar
Your fuel trims will give you those answers.
Old Aug 21, 2009 | 05:04 AM
xspsi4's Avatar
I know it is not right but it seems liveable other than the cel, I drove it 1,100 miles round trip to the shootout and it was fine with the cel off for 400 miles at a time but once I get back in town it throws the lean code so I am unsure as to why.
Old Aug 21, 2009 | 05:21 AM
Mellon Racing's Avatar
your afr might be "ok" at idle/cruise but your fuel trims might be pegged to get you there, your injectors settings are wrong.
Old Aug 21, 2009 | 06:37 AM
20gmr's Avatar
did you change the latencies table at all? if that is still stock try adding .2 to all of them, that got my 880's dialed pretty close. I had trims in the 3 % range
Old Aug 21, 2009 | 08:02 AM
jrohner's Avatar
Yeah, you probably have the latencies set wrong.
Old Aug 21, 2009 | 10:23 AM
xspsi4's Avatar
Ok so the 713 scale is ok then? I will report back on the latencies.
Thanks for the help!
bradswims11
May 26, 2023 11:19 PM
mrfred
Dec 15, 2022 11:13 AM
EyeDreamt
Nov 22, 2012 04:04 PM
03lances
Apr 26, 2010 01:47 PM
