The DTC Disable thread (P1235, P1241, P1238, etc)
Old Aug 30, 2009 | 03:57 PM
  #61
tephra's Avatar
oops fixed
Old Aug 31, 2009 | 03:31 AM
  #62
BigT's Avatar
Tephra, thanks for all of this posting, but its making me wonder if my car is slow or fast. lol I've hit one of the airflow limits once a few weeks back. I adjusted the right tables and have yet since gotten any of the CEL's in regards to airflow. And, according to VDR, my power has gone up. I guess my question is, if the car is tuned right, is any of this necessary?
Old Aug 31, 2009 | 09:01 PM
  #63
LIGHTSPD's Avatar
The airflow maps are checks put in place for the DBW setup. I actually took our shop car and cut all the airflow maps in half and did the fix and guess what everything was perfectly still in check. The biggest problem is when you start making large power these maps become a night mare. No one has really come up with a formula for what they are looking for and how they all interrelate. This solves that problem completely.
Old Aug 31, 2009 | 09:51 PM
  #64
EVOXSILVER's Avatar
I just wanted to add a very useful tips for all the "BOV VTA ricers " (I'm one of them) apply the DTC Disable patch and no more part throttle problems !!! I did the test for the last 3 days and it's working perfectly. i'm now going back to stock, the HKS SSQV is really anoying.
Old Sep 1, 2009 | 08:43 AM
  #65
Whitewind's Avatar
Just wanna say I was having problems with Limp in 5th gear part throttle using Gunzo 91oct map. I did lots of logs and was not in the boost limts they are set pretty high limits. Did DTC setup and work great got be in the air/flow limits then right? Thanks tephra for all of your help on this. (went pull code and are autoparts store got there scaner stolen.) also im at 5000 ft here in Wyoming if that matters.
Old Sep 1, 2009 | 08:47 AM
  #66
Mellon Racing's Avatar
lol at people downloading free tunes..what do you expect.
Old Sep 1, 2009 | 09:36 AM
  #67
Whitewind's Avatar
hahaha..... Atleast people are helping out around on this forums. Im learning self tune my own car man. Did not ask for smart *** comment. Just because its taking work away from you guys don't mean you got bash people for what they want to do. If i wanted go with E-tune I would have went that way. Anything wrong with that?
EDIT: Also its not a free tune its a starter map. Its 100% safe to run (IMO). Evoscan tells it all and i can work off it from there. If there something wrong with people helping other out let me know?
Old Sep 1, 2009 | 10:16 AM
  #68
you're right, I apologize for offending you, good luck with the self tuning endeavor.
Old Sep 1, 2009 | 10:36 AM
  #69
Whitewind's Avatar
Thanks man. Nothing against you guys at all. And I really mean that. I living in BFE where not a tuner around for 100's of miles and I like to do my own thing just need little help from people on this forums to start me out that know whats going on and have been doing it for yeah people like you that know your ****. Never know I plan to move to Ky paducah, Benton Area soon. So hell you might be tuning it someday.
Old Sep 1, 2009 | 10:47 AM
  #70
none of us came out of the womb knowing it all so kudos to you for picking it up and running with it, that's the same thing I did too. Certainly give us a shout if we can help.
Old Sep 2, 2009 | 11:39 PM
  #71
saintspall's Avatar
Originally Posted by tephra
oops fixed
What bout 52360016
Old Sep 6, 2009 | 01:20 AM
  #72
tephra's Avatar
Hi Guys,
Can the people getting P0140 OR P0138 for the rear02:
1) check that your ECU OPTIONS 2 points to 0x50082
2) Post up the HEX of 0x50082
3) Log 0x8087FE (2byte)
4) Log 0x8087F0 (2byte)
Post the results
I have looked at the code and can't see anything obvious as to why 526800XX differs from 530400XX in this regard.
Thanks!
D.
Old Sep 6, 2009 | 05:22 AM
  #73
tephra's Avatar
P0247 added but untested...
Old Sep 6, 2009 | 07:12 AM
  #74
jason4656's Avatar
any chance for 52370024
Old Sep 6, 2009 | 05:46 PM
  #75
tephra's Avatar
P0247 is confirmed as working (for 53040010 at least, be a bit cautious on 526800XX )
Still need an answer to me P0140 Q above..
