The DTC Disable thread (P1235, P1241, P1238, etc)
What's the AWC Update Reflash? If this is the entire rom they are writing then yes it would reset those values to stock. Since your table access in EvoScan would already be setup, you would just need to read in the new ROM and change the values again then write it again, although you may have to verify that the ROM has all the values in the same spot.
^According to the sevice manager, the updates modifies the ECM to reduce the load applied during warmup.
Due to the limp mode from my Jun TB, I`m currently running the stock map with the DTC codes disabled using Ecuflash. Will be doing the conversion from my Cobb Map to Ecuflash this weekend after my visit to the dealership. I just wanted to make sure I can back to the shop without the limp mode hitting on me.
try this today on 5304007, car stil go into limp mode, on part or full thortle
car mods : kelford 270, full intake, ultimate tbe, ams cooler, greddy bov, hks evc 6
why it happend? have i another way to solve this problem?
car is very fast, but 1241 is big problem.....((((
53040007
Code:
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="631b2" type="1D" scaling="Hex16"/>
<table name="DTC P1241 Disable 0x03E8 -> 0xFFFF" category="Misc" address="631a8" type="1D" scaling="Hex16"/>
<table name="DTC P1235 Disable 0x0026 -> 0xFFFF" category="Misc" address="549bc" type="1D" scaling="Hex16"/>
i have change this values... is it right?
53040007
Code:
